Engine enamel
Snorkus, filters, throttle bodies and intake manifolds.
THAWA
Engine enamel
Post by THAWA »
Is it okay to use this stuff on the intake manifold?
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
LegacyT
Post by LegacyT »
Yes it is, do I sense an STi red manifold soon to be :wink: :D
Mark,
THAWA
Post by THAWA »
If this is sti red then yes you do :)
scottzg
Post by scottzg »
ewww! poor man mods!
THAWA
Post by THAWA »
Damn yes
There's an etching primer for aluminum that you should use first so the paint doesn't flake off. I forget the name of it, but I believe there was a thread on it before if you search.
ciper
Post by ciper »
If you take the time to enamel the intake you might as well do other work while your at it. Parralel fuel mod and replacing the Knock sensor + Purge valve come to mind.
look who's back :)
I just had the intake off last weekend.....the parallel fuel mod is a little more involved on our cars......mainly because the wonderful fuel adapter that they use on the scoobymods site is gone......If I would've had a second car I probably would've tried to rig something up. My reasoning was that for a n/a motor it wasn't that critical.
