I thought the early 1.8L and 2.2L NA also had single layer HGs from the factory....I could be wrong. I am still very new to EJ22Ts
in other news, I am on hunt for a proper (cheap) engine hoist. Once I get that I can get to work on this swap! Still collecting a few parts for after I get the motor up & running.
things I am going to need oncer the motor is swapped in;TD05
-trim piece for the passenger rear quarter.............
-TMIC ................................................................check
-TD05 16g w/ 90 inlet...........................................
-STi injectors (yellow or pinks)..............................
-headers.............................................................check
-uppipe...............................................................
-downpipe...........................................................
-catback.............................................................
-emanage of some kind........................................
-bodywork on rear wheel wells & rockers...............
-paint.................................................................
so I got my work cut out for me, now that my RS is all set I can get going on this
I know a lot of ppl use revtronix here to handle mods just like this. Is the revtronix unit limited to ONLY the parts on the prereq? or can I use the turbo I want with bigger than 440 cc injectors??
