In short my goal currently is
91 turbo legacy engine as a starting point
Replace all wearable items no matter condition
02 WRX heads, bored to 96.9mm ringed and shortened to reduce head volume
Metal head gasket, .8mm preferred but most likel 1.52mm with arp studs
4-2-1 headers, slightly larger turbo, 3 inch twin dump DP/CAT/Resonator/Muffler
~500CC injectors
Air water intercooler with temperature sensative two speed pump and large exchanger
Custom spark plug wires to match now center mounted spark plugs, diamond coil pack and MSD ignition module. Staging RPM spark limiter which "should" act as a anti-lag (still have to test this one)
6 speed manual transmission non RA (standard viscous center diff) with mechanical front diff and viscous rear or
Level ten built Automatic
Electronic boost and fueling management
Plenty of gauges
Small internal parts will be new stock items (rings/bearings and such).
So far one part I need help on is sourcing the head gasket. Here is my dillema
The engines I have seen, ej25 and ej22, have the pistons flush with the deck surface when at top dead center. I would assume the ej20 to be the same. This means we only need to calculate area of the new engine combo.
Look at these numbers, tell me what you think
EJ22t stock bore 96.9mm stroke 75mm head chamber? 40cc piston volume 28cc gasket thickness 1.52mm calculated compression 7.98:1 published 8.0:1
EJ20t stock bore 92.0mm stroke 75mm head chamber? 49cc piston volume? 17cc gasket thickness 0.80mm calculated compression 7.99:1 published 8:1
The head volume of the ej22t was a guess based on the published compression ratio. The 49cc head volume for the ej20 was published by cobb tuning. The piston volume was guessed based on published CR.
Obviously these numbers should be verified but it gives us an idea. Not I calculate my new engine to have:
EJ22 combo bore 96.9 stroke 75mm head chamber 49cc piston volume 28cc gasket thickness? .152 calculated 7.27:1 CR
Realize this also doesnt consider the rebore of the head from 92 to 96.9 which will reduce compression even farther, 7.22:1 depending on how "deep" into the head. This is lower than I want. If I was somehow to use the smaller .8mm gasket from an ej20 the compression would raise to 7.67. As you can see a small change in gasket size makes a "large" difference in CR.
My current solution involves shortening the height of the head, basically milling the entire head surface down. I have to look closely at the valve lift because I dont want to create an interfearance engine in the process!
At first I was also planning to create my own stroker kit. This is still a secondary option.
Stock EJ22T has a 9.69 bore and 7.5 stroke
Stock EJ25 has a 9.96 bore and 7.9 stroke
If we kept the EJ22t pistons and used the EJ25 low end we would have:
Displacement = Stroke * * (Bore / 2)^2 * [# of cylinders]
Displacement = 7.9 * PI * (9.69 / 2)^2 * 4
Displacement = 7.9 * PI * 23.474025 * 4
Displacement = 7.9 * PI * 93.8961
Displacement = 2330.36805388979 CC
2330.36805388979 CC = 2.33 Liter (rounded)
2.33 liter is a small increase, but it seems that it would be a VERY cheap increase.
2.33 liters plus better flowing DOHC heads compared to the stock EJ22 or the increased Bore of 4.9mm + stroke of .4mm compared to an EJ20 is significant.
This power will be put to the ground with some 215 45 r16 falkens, compared to the stock 185 70 r14 thats 15mm reduced diameter or in other words a nice mechanical advantage
A worldwide switch replacement at work is has killed much of my time. One office alone has 9 Cisco 4507 with 288 10/100/1000 ports each (yeah gigabit to the desktop) and two 6513 plus a random assortment of 3500 smaller switches. I also just moved to the other side of the bay. My XT6 broke one of the timing belts (it has two) and my other legacy needed a new alternator and battery. Ive also been helping my friend replace basically the entire front drivetrain of his MX6. The BBS was something I just didnt have time for even though I had some questions to ask. One funny problem I had was my other Legacy's sunroof got stuck open! After taking alot of stuff apart I found out a light punch to the middle of the ceiling makes it work perfect
The "joint venture" GL-10 turbo 5 speed my friend and I had has been donated. Too many crazy full throttle runs made this tired car ready for the graveyard. It still ran when we donated it, upside down WRX muffler and all
We decided to weld front and rear differentials of a legacy wagon we got (traded for a pentium II laptop) and use it as our new dirt thrasher. We also have a puke smell blue wagon with a recently blown headgasket that will probably be stripped. For some reason we cant get rid of the puke smell!
This is probably a tenth of the information Ill share. The custom gauges and electronics Ill be using will be left for another post.
