Dome Light issue
Baddog
Dome Light issue
Post by Baddog »
My dome light works when I set it to the on position. But when any of the doors are open (when the dome light is set in the auto position) it doesn't work.
What do I need to look for. Is there a fuse or something? Thanks
1996 Subaru Legacy L
1993 Subaru Legacy SS
1992 Subaru Legacy L
1990 Subaru Legacy L
no_one_special
Re: Dome Light issue
Post by no_one_special »
it could be a fuse . it could also be a door switch. do all the doors have the same problem? or just oen door.? if its all doors then its a fuse probably. if its jus toen door it shouldbe be the door switch.
Baddog
Post by Baddog »
It's all the doors. What fuse could it be?
Baddog
Post by Baddog »
Bumpity.
I can't see all the door switches being bad, so it's likely a problem either with the switch itself or the power wire coming from the switches to the auto switch.
I'd check for power on the wire going to the "auto" switch.
def09
Post by def09 »
When I swapped AT meter out for 5 speed meter. My dome light acts this way now. I leave it off.
subaru_styles
Post by subaru_styles »
when i was removing my sunroof the frame got caught on the dome light wires, yanked and i herad & smelled an electical short. have the same problem now of it not turning on with the doors. havent looked into tracing that wire yet
1994 SS "JDM-OEM"
1994 gt wagon, next build
1994 turbo wagon
