Well I found a mint rear center reflector at the U-Pull yesterday off a '90 L so I pulled it off to replace my cracked up piece.
I tested some methods of removal for the badging while getting the Legacy L badge off but ended up breaking it...
I did however get the Legacy Turbo badge off successfully!
Here's how I did it:
I heated the emblem with a hair dryer until it was hot to the touch, then I got some fishing line started unter on of the corners and started working it back and forth while heating the top & the bottom. I took my time, it took about 20 minutes to get 1/3 of the emblem free. Once I had 1/3 started I wedged a small screwdriver under the edge of the emblem just to provide a slight amount of lift. I then squirted GooGone under the 1/3 edge and let it soak in while continually heating the emblem top & bottom. After about 10 minutes of soaking & heating I started with the fishing line again. After about another 20 minutes of heating, GooGone & fishing line and even a few gently pry's with the screwdriver the badge popped free.
Words of advise, take your time. If you attempt to rush this you will break the emblem. While cleaning the "goo" off the back of the emblem I did end up removing some of the gray paint. It just so happened that I had some matching touch up paint to fix the paint that had come off. The proper color to "repair" the emblem is: Subaru Touch Up Paint - "Slate Metallic", Code # 943, SOA Part # 308M147.
