This Aluminium Brake Cooling Duct ensures cool air reaches the brake rotor, providing increased cooling and reduced risk of brake fade.
• Attaches to the standard lower arms
• Flows fresh cool air into the front wheels
• Provides enhanced brake cooling for heavy brake use
• Duct are made of Aluminium molding
• Attractive high quality Aluminium finish
Are the only ones that carry air into the disc, hub area, a key part to cool the disk itself as it is from them that take air for the ventilation. The other solution would be to bring the pipes, but the work is much more complicated.
I already did the mountains and along with some other aids on the track I found.
The centerpiece is identical at the carbon model, the upper and lower bent parts are welded to make the piece more durable, while maintaining the exact same yield functional.
Color:
painted black
The assembly is extremely simple, if you have the possibility to lift your car you'll mount the deflectors in 30 minutes. The finished piece is Plug and Play, it takes 2 rounds ( washers ) to convey that if you want you can even get you free.
Also will be shipped with instructions for assembly.
If you want more photos (even more definition or photos of brake duct mounted on ) and also installation instructions, send me your email address and we will forward all that I have available.
Required payment method: Paypal or bank transfer
Total price with worldwide shipping included: 150 USD
