[FS] 1993 Legacy SS - Low miles ,excellent condition for age
oldbluelegacy
Post by oldbluelegacy »
Hey guys I am thinking about selling my 93 SS , more of a feeler than anything.
Here are some details.
93 SS
White ( pretty rare)
118k miles
5mt
Power options: PW -PDL-PS-AC(cold)-P moon roof fancy driver seat controls with lumbar and psb
Cars interior is immaculate. Hard to ever find one this clean All accessories work correctly INCLUDING power antenna
Cars body is great, some surface rust on bottoms of fenders and there is a dent in the drivers door where previous owner had the door open and clipped his fence post , other than that car is nice . Needs a good buff job. quarters have bubbles no holes at all ! The inner fender is in excellent shape .. SOLID as can be.
I just changed the back struts and when doing so I undercoated the wheel wells and the bottom of the car with rubberized undercoat and some spray undercoat for the hard to get areas. the undercarriage of this car is immaculate . SOOO CLEAN .. Hard to find any first gen leggies this clean let alone a SS.
Car runs and drives GREAT I had big plans for this car , but my father is pretty sick in the hospital right now so I have to clear out my toys to help him out .
It's a very clean car for it's age, I got it off a friend of the original owner, he kept it in a garage in NJ it's whole life until his wife bought a new car and kicked it out. He couldn't hold on to it anymore so that's where I came in.
New parts on the car include:
Brand new back OE replacement struts
BN R KYB strut bellows
BN R Monroe Strut mounts (tophats)
New WRX master cylinder
New Slave cylinder
New Knock sensor
New Purolator air filter
I replaced the Valve cover gasket on the Passenger side because it was leaking on the exhaust . Never got around to do the DS. Have the gasket though.(still remnants of oil on exhaust . and hiding places . Smell almost gone)
Clutch was replaced with an Exedy stage 1
Axles all were replaced at 100k
Timing belt and accessories was done at around 105k
Car always used Synthetic oil changed every 3k with either Castrol or Mobil 1 with purolator filters (the best)
Trans and Diff fluids changed with syn before i got it.
Tires on the car are good and I will include a few extra singles for it as well.
Car runs great and pulls hard , has 0 running issues. Has a CEL for a bad purge valve solenoid which does not effect performance at all . In fact I have 2 other purge valve solenoids in hand to give to new owner if you feel like changing it. I was going to change it when I upgraded the turbo. The car was never modified , it has all stock components but I had big plans.
So here's the deal , I would like to get around $4000 o.b.o in stock condition.
_____________________________________________________________________________________
Here is the second package option I call it the stage 2 option.
Included in the stage 2 option
TD04 turbo off wrx with 12k miles on it
Revtronix Chip installed in a 1991 Turbo ECU
SSM-type Cable purchased from Revtronix for use w/the Revscan software
JECS MAF
JDM 440cc injectors (bolts into rails)
06 STI downpipe
06 STI axleback (no midpipe I was going to get my own custom midpipe made)
06 WRX Intercooler
Custom Silicone Y pipe ( that I believe will bolt the WRX intercooler right up with no mods)
New Foam Hi-Flow airfilter (i believe I have a MAF air flow adapter as well)
Coffee cup mod (made from expanded exhaust sections)
Bosch wires
Iridium plugs
"The chip upgrades the stock ignition and fueling maps, removes the stock 13 PSI fuel cut, properly recognizes the JECS MAF, and bumps boost to 16.5 PSI in Power mode; 14 PSI in Normal mode. It uses all the stock components/sensors, such as Boost Control Solenoid (BCS), MAP sensor, etc."
with the stage 2 package I am looking to get $4800 O.B.O
or I may be willing to sell the whole package separately from the car for $1200
So to wrap up , car in stock form for $4000
or stage 2 kit included for $4800
Will post good pics when it stops raining here.
04 Fxt -Aspen white- sti bolt ons
05 Saabaru 9-2x
02 Impreza OBS 5mt - for sale
02 Aspen white WRX - for sale
97 Legacy outback
93 Mazda mx-3
93 legacy Ss -sold
oldbluelegacy
Re: [FS] 1993 Legacy SS - Low miles ,excellent condition for
Sorry posted here , forgot the car lot was here .. Here's a link to a post with pics
http://bbs.legacycentral.org/viewtopic. ... 72#p357972
05 Saabaru 9-2x
97 Legacy outback
93 Mazda mx-3
93 legacy Ss -sold
