My car died last night on the way home. It just kind of sputtered to a stop and then nothing. It won't turn over, it won't even struggle to turn over. My first thought was the fuel pump so I took the line coming from the filter under the hood off and pressed the gas. Fuel came gushing out so I ruled that out. Checked the spark coming from the coil pack...got spark from all four. At that point I gave it up for the night and went home. Today I came back to my poor turboleg and tried to turn it over, hoping against hope that it might start. No such luck. So, here's a list of Codes...
21 - water temp sensor
22 - knock sens
23 - Maf
32 - O2 sens
41 - a/f leaning control ?
45 - MAP atmosphere sens
49 ??? no idea - four long blinks nine short ones.
So I checked the fuel pump. checked for spark. Took out the MAF and cleaned it with MAF cleaner and I checked the vacuum hoses. I'm lost but I'm leaning towards the MAF because of the way it won't turn over. I recall that when you try to start the car with the MAF disconnected it acts the same way. Oh, I also took off the timing belt cover to see if the timing belt was turning and it was so that might rule out the crank sensor. One thing, I have a rear CV that clunking (needs replaced badly) so I put in the FWD fuse for the ride home fearing that the CV might go out on me. I don't know if this matters but I think not because one other time when I did that it was hot out and I got an 'At Oil Temp' light. I shut the car off immediately and let it sit for an hour or so. It started right up. Even then the car would start, just not move. Any ideas?? I need help desperately. Thanks
