USDM WRX shift linkage
mTk
no title
Post by mTk »
I did a search, couldn't really find a definitive answer. Will the USDM WRX shift linkage assembly directly bolt into our AWD 5MT BC Legacies?
I see talk of an adapter needed for the STi linkage, is this needed for the WRX linkage? If so, anyone have a part #? Any other issues i may run into?
MK
1992 BC672 AWD 5MT
HomeSlice
Post by HomeSlice »
MK-
i would say its for sure that the wrx assembly would bolt right in. with the adapter you got from me. it would of worked out for me but the fwd bottom linkage is longer.
cheers,
Jim
93BC"edm" 93GC 90BC R.I.P.
Post by entirelyturbo »
With said adapter, yes it should work...
I bought a short-throw shifter from xcceleration.com back last Christmas. I then discovered it would take some fabwork, and I decided I'd rather have the $250 to do other stuff with, than fool around with it...
*Formerly DerFahrer*
i believe for the turbo legacies everything bolts right in.......as mentioned with the other ones.....may have some customizing.
