Poss engine swap.
allan102
Poss engine swap.
Post by allan102 »
I hope someone can help. I have a 94 turbo wagon with a dissembled motor. I have most all parts but can't work on it any more. Hurt back real bad. And like many these days there is no money even if I could find some one to work on it.
I have a non turbo ej that runs ok and I am wondering if any one has made this swap and what problems were encountered. For help I will probably have a helper that may know which end of a screwdriver fits the screw.
Allan
Falken-18c
Re: Poss engine swap.
Post by Falken-18c »
i think all u need is the ecu from non turbo and your harness will work but dont take my word for it
Falken-18c
my first motor i took out by myself lol took me a week to prep lol like 3hrs pulling after diconected well i had tranny with it and thats making sure i dont break nothing but with just the motor it took me an 1hr and a half not realy rushing my secound time i just took the drain plug out of rad took off top intake manifold then 2 motor mount bolt then every thing was drained removed all that then 4 trany bolts i only had a lil problem seeing the one driver side botom one then the 4-6 bolts out of the torque converter are whatever it is to split the block
TOOLS 10-14mm sockets 3/8 breaker bar and a flat head screw driver and a crow bar
also i the exhaust manifold lol i used a crane but if u had 2 ppl could probly pick it out but not you with your back lol i wouldnt try only said that because me and my father picked it up and tossed it on a truck and im not big at all 6ft 170pounds
Grayguy
Poss engine swap.
Post by Grayguy »
What's wrong with the turbo motor that you don't want put it back together? If there is something wrong in the short block I would just swap the NA shortblock in and run it like that.
Also, I've never understood why anyone pulls the intake Mani off before they pull the engine, it's a completely unnecessary step.
92' SS: SOLD
Falken-18c
yea i know your right you dont but i didnt know what i was looking for then later saw with intake manifold on my 22t but probly easyer with off i think
