I´m novice here, hope that´s a good category for this topic. If not, sorry.
Few mounts ago I make a swap EJ20GN engine (IHI VF12 turbo, 5speed manual,water cooler) from legacy I to my GC8 impreza. Everything works
We made several modifications - steel headgasket, 3->2,5 downpipe, TANABE 2.5 exhaust, Thermotec on manifold and downpipe, STI ver.3 intercooler, Intercooler water spray from RA, Oil catch tank, walbro 255,sti clutch, Elec. boost controller.
Turbo is in good conditions(don´t want to change it).
I would like to get 260-300hp. In case of setting the pressure more than 1bar, ECU make a fuel cut.
I do not want to use programmable ECU.
So, which Subaru ECU is best for me? (Z4....)
Or do you think is better to use the TF05 turbo, STI injectors, AFM and ECU?
Or is there some better way to get more HP?
Please Help. Thanks very much.
Matus
