Recently broke a wire off of my pigtail on my 1994 Legacy, and I have it loosely soldered in but I doubt it will hold very long.
Dealer doesn't have a pigtail, nor do any of the parts stores in my town.
Just looking for a pigtail so I can install it and not be scared that my solder will fall out after every bump in the road.
Thanks.
WTB: Coolant Temperature Sensor Pigtail
2015 Subaru BRZ
1993 Subaru Legacy Sedan 5 Speed FWD Green (EG33 swap in progress)
1984 Subaru BRAT Tan
Re: WTB: Coolant Temperature Sensor Pigtail
you might want to try an injector plug, cant say for sure but it htink they're the same
Wow, I haven't even thought of that! Going outside right now to check the plugs. I'm sure I'll be able to locate an injector pigtail easier than a coolant sensor pigtail.cj91legss wrote:you might want to try an injector plug, cant say for sure but it htink they're the same
2015 Subaru BRZ
oh yeah, they're easy to come by. as a matter of fact, i have an ej20h cam sensor on my car and used an injector plug and made a harness to work. Worked out great!!
