Altitude question.
Re: Altitude question.
I'm assuming that is your vacuum reading at idle....correct?
Based on this chart
http://www.engineeringtoolbox.com/air-a ... d_462.html
There's a 3.6 in HG difference in pressure between sea level and 3,500 ft. Since you want between 19-20 in HG vacuum at idle, your reading of 16 in HG is good.
Based on this chart
My Vacuum at ilde was ~14inHG here at 5500' ASL (perfectly normal). Now with delta cams it runs 10-11inHG at idle (a bit low).
Old - '93 T-Leg - 14.693 @ 92.68 at 5800ft ASL (Bandimere Speedway)
New - 07 Spec B/stg 2
"bloodstains - speed kills -fast cars - cheap thrills -rich girls - fine wine
i've lost my sense - i've lost control - i've lost my mind" Agent Orange
