radiator compatability Q
92L FWD, automatic. Rad is on its last legs and since I had to remove it to do a timing belt and water pump I thougth I would replace it. Local guy has rad and fans from an 00 Outback for a decent price. Fit? thanks
Re: radiator compatability Q
No I don't believe the 00 Outback radiator will work.
would a 96 Legacy L radiator work in my 94 thinking of swapping mine.
'04 forester XT
Scoob Alumni
'94 TW, '96 L, '00 GT
Scoob Alumni
I'm assuming your 94 is the turbo correct? If so, no it will not work.
