Hi there. I have a question about the vacuum lines the run on the turbo.
There are two
One goes to the WG then the other one T's to the nipple on the comp. housing.
I swapped out my stock VF11 for a fatty GT28 and does not have the nipple on the turbo comp.
Where can i put that other line?? Any place the can get boost from?
Thanks!
Turbo lines
Turbo lines
93 Legacy Turbo AT Sliver Stock, Ultra Rotty Body
93 Legacy Turbo MT Silver Rob Tune 550cc Lowered GT28 AWIC 4.11 05 Leg GT rims Mint body
95 Chevy Corvette MT ZR-1 Black X Brace Chipped
94 Legacy Turbo AT Blue Stock SOLD
06 Pontiac G6 AT Green Stock SOLD
Re: Turbo lines
It should be as close to the turbo compressor outlet as you can get it.
Re: Turbo lines
Ok. So just get that line as close to the turbo outlet as possiable.
So what if i were to plumb it into my intercooler. I have two remaining holes in my cooler that i can easily use.
Not to mention that they are threaded! WHOOT!!
If you think that is close enough i will just thread in the right brass fitting and be done with it.
BTW!! the intercooler is top mounted air to water cooler.
Or does it have to be before the recirculator valve?
Tom.
Tom.
Re: Turbo lines
It should be closer IMO, but if the intercooler is all you have, then that's what you'll have to do.
Re: Turbo lines
Thanks for the quick reply. I think i got a better place for it now. I have a120 degree pipe that i can tap into and stick a barb into it right at the turbo outlet.
I think it would work the best and look better there aswell.
Thanks!
Thanks!
