This is about some Select Monitor Data that I've collected from my Subaru with 1992 Legacy Turbo 2.0 engine.
I've made an overview of all the menu's available, what values I should be getting and in red my actual measured values (ignore these for this problem).
All these values are coming from the Legacy I FSM
In chapter 2.7C also this overview of the 4 switch input menu's:
My active switches (Led On) with warm engine idling, transmission in neutral:
FA0:
1. IG
7. NT
FA1:
1. ID
6. FP
FA2:
FA3:
10. OR
Some questions and remarks on these values:
- I put in a supposely good o2 sensor in my car. When I start the car, the A/F (lambda) voltage goes from 0.30V steadily to 0,0V.
- With this happening, my ALPHA value, after climbing to say 18%, also steadily drops to 0,0%
- After the A/F and ALPHA gone back to zero, my LoadData ends up at 12, way under the specified 30-50.
- Regarding F11, why is my injector pulse width lower than specified?
- Regarding FA03; LED 10 is on, indicating a rich mixture, even when my lambda voltage stays at 0,0V. Why is it indicating a rich mixture while my lambda voltage is dropping to zero?
I could use some Select Monitor Guru input here, or some verification of someone with some data of a Legacy I Turbo or MY95/96 WRX.
For some reason my car's been running crap for some time now, and after checking and replacing many things, this lambda, ALPHA and LoadFractor value is the best I can find what's currently clearly out of spec.
Hope someone can help me on this. Has anybody earlier see his lambda signal falling back to zero during warm up? Let me know.
gr. Bram
