HID Kits
Re: HID Kits
How did you test them?... Installed? Which headlight is the main harness hooked up to? Are your grounds good?
If they are installed make sure you're getting power to your factory low beam harness.
If everything checks out and still no low beams it's probably a fault with the HID kit.... or it's only a single beam kit![Confused :?](./images/smilies/icon_confused.gif)
Re: HID Kits
Yeah, tested by just connectin the wires. The ground was good and low n high beam wires had power too. I was able to figure it out on another forum where a guy had the same prob; the solution was simple: invert the polarity of the connectors to the ballasts. Thanks nyway bud.
Re: HID Kits
heh i was having the same problem with mine..
Re: HID Kits
So did you guys that have a kit do a retro fit? If so what did you use for housings? I want to do a retrofit but the plastic on the front of these is hideous. A retro fit would be a waste of effort.
If you are just putting HIDs in the factory housing disregard.
-Lindsay-
2005 SRT-4-Track Slut
1991 Legacy SS-DD/Tinker Toy
Re: HID Kits
yeah mine are just in the stock housing
Re: HID Kits
so basicly i flip the connectors and my hids will work on low beam?
