1994 leggy N/A parting out
				edgeofvamp
Hey guys i am going to be parting out a 1994 leggy, due to vehicular cancer getting out of control. The rear third of the rockers and the rear quarter panels are bad.
I picked up a 91 leggy with zero rust and after i get the parts swapped to fix that 1 up, i will be posting all parts that are available.
If you want more info before that, just post- i will be checking daily.
Sorry forgot to mention that it is a 5 speed manual.
						Re: 1994 leggy N/A parting out
im looking for headlights, corner lights, 5mt tranny, driveshaft, diff.'s, shifter, etc..
							93 Legacy l AWD 5mt
87 GL-10 Turbo 5mt
						87 GL-10 Turbo 5mt
				edgeofvamp
the headlights are a little hazy, but still good
corner light passenger side is good, but driver side is junk
tranny is a 5MT and is still good; shifts smooth-stays in gear
there is no front or rear half shafts- i had custom heavy duty shafts and they are going in the new car
i do not know the status of the rear diff
the shifter is in good shape, but the bushings are getting wore out
Anything else?
Anything else?
do you have a factory fog light switch?  delay wiper stalk (for wagon)? thanks
				edgeofvamp
Sorry no factory fog switch
is there a difference between the sedan and wagon wiper stalk?
yes, the wagon will have the rear wiper on the stalk as well.
				edgeofvamp
thank you silver, i haven't owned a wagon yet, so appreciate the clarification.
I do not have a wiper stalk for a wagon, but i do know of a couple leggy wagons in a junkyard near here that might.
I should be going there next week, so i will be able to look for you.
PM sent about some goodies.  check your inbox, please.  also, looking for the subaru trunk badge.  it's like trying to find the pot of gold at the end of the rainbow.  no one has one.
thanks
						thanks
Im interested in the oil Pan and the 5m tranny
				edgeofvamp
hey dkopp, i am sure that 1 of the 2 cars have 1 i can get or else i found a 93-94 in the junkyard a couple miles away that probably still has it.
If you guys need any other parts i might be able to find them on that car too, it was hit right behind the passenger front tire.
The fender, chassis corner and door are toast; but everything else is fine.
Hey opaphis, the oil pan has a dent in the front drivers side, but has zero leaks.
The downside is that i would like to sell the motor complete, since it still runs and whips up through the rpms fast as hell.
excellent.
if you have a line on any of these and they are clean and the yard isn't charging out the ying yang for parts here's my list:
trunk carpet
coin tray
trunk release lever
coolant overflow cap with rubber overflow tube
front drivers and passenger rear door cards in the 93-94 turbo black color
subaru trunk emblem
thanks
i can't believe there are junk yards with subaru's. all i have are dodge neons. i should just turn mopar.
trunk carpet
coin tray
trunk release lever
subaru trunk emblem
thanks
edgeofvamp wrote:hey dkopp, i am sure that 1 of the 2 cars have 1 i can get or else i found a 93-94 in the junkyard a couple miles away that probably still has it.
				edgeofvamp
Well where i live you cannot drive throughout town with out seeing a leggy or 2.
Subies are a big deal here and everyone and there grandma has 1.
Unfortunately people don't take quite as good of care as they should.
Well if you come across one or change your, i could really use it mine has a really bad leak. Im also looking for and inner wheel bearing
