So I purchased a 92 Legacy Sport Wagon yesterday. It has an auto, which has no reverse. I have a 5MT from a 90 Legacy N/A Wagon that I scrapped. I am fairly certain the code is a 752 series with A1AA at the end. I'm also fairly certain that it has FD of 4.111. Obviously, the Legacy Sport has FD of 3.90. So This is the rough draft of parts I need to for the swap. Let me know what you think and if I'm missing anything.
Front axles for a 90 Legacy N/A Wgn
A rear end from a 90 Legacy N/A Wgn(4.111 FD)
Clutch Pedal assy from 90 Legacy N/A Wgn (cable clutch)
Clutch(aftermarket) and Flywheel for 90 Legacy N/A (or Turbo? shouldn't be different, right?)
Drive shaft from pretty much any Legacy Wgn Manual.
Manual Transmission Mounts for any first gen legacy manual.
