trouble code 11 - crank angle sensor
1evlwrx
Post by 1evlwrx »
my legacy just recently started flashing a code 11, i was wondering if anyone on here would happen to have the sensor for sale, and if so how much shipped to 85044 (phoenix, az)
thank you,
joseph
Jessekrs123
Re: trouble code 11 - crank angle sensor
Post by Jessekrs123 »
Before you go buying a new one, check on the condition of the sensor first. These things are list price from the dealer for like $230. I'm sure you can find one cheaper, but it is certainly an expensive part to replace without even inspecting it first.
Remove the sensor, and clean off any dirt from the magnet. Also check the condition of the wires to the sensor, make sure there aren't any exposed wires that could be possibly shorting out.
2015 Subaru BRZ
1993 Subaru Legacy Sedan 5 Speed FWD Green (EG33 swap in progress)
1984 Subaru BRAT Tan
1evlwrx
Post by 1evlwrx »
I did some searching on this part and was amazed by the price.
I will check it and clean it prior to shelling out $230+ for it.
thanks for the feedback.
Does the car run ok besides the code 11? If you had a problem with the crank angle sensor, the car would likely not run.
1evlwrx
Post by 1evlwrx »
yeah it runs fine, the only problem i have is with the automatic tranny. but i don't think that the two are related to one another.
Have you tried clearing the codes? More than likely that code was a false code, especially if the engine is running fine.
