Power light flashing!! binding while turning
criticalm@ss
Help guys, I did research all I could find is some hankshake method.
It flashes 16 times when i start it and binds when i turn like a stutter.
Help!!!!
Duty C solenoid??
Help!!!!
Duty C solenoid??
92 Leggy Wagon L~2003 Baja~2006 Sti
criticalm@ss
Re: Power light flashing!! binding while turning
1992 legacy L a/t.
the 16 flashes means the tcu has a code. it could be any code
Binding in corners could be many things.
1. thing it could be is mismatched tires, tires not evenly sized to 1/16"
2. It could be wrong rear diff ratio for trans
3. it could be clutch packs failed in the rear output of the trans
4, it could be duty C
5 it could be combination of 1 or all of the above.
but if you get 16 flashes there is a code to get. read up on how to get code. goes like switch on , put in D, press manual button, key off, put in 3, key on, press manual, key off, select 2, key onm press mnaul etc etc etc...
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
criticalm@ss
so do the hank shake method??
thanks btw.
Can an obd1 reader tell me?
thanks btw.
Follow the instructions on my site for pulling the TCU codes and report back on what you find.
www.surrealmirage.com/subaru/trans.html
criticalm@ss
Awesome brother, it worked had to press unlock button to get it out of park.Legacy777 wrote:Follow the instructions on my site for pulling the TCU codes and report back on what you find.
http://www.surrealmirage.com/subaru/trans.html
code 24 2 blinks followed by 4 quick ones.
Ok so I am at 246k do i need to do clutch plate while its open or just look for wear and replace solenoid?
Duty c right?
thanks.
What I would suggest is clearing the TCU codes by pulling fuse 14, (EGI/TCU) for an hour or so. Then check to see if the code comes back. It probably will, but it's a good idea to just double check.
Also, here's the diagnostic tests from the factory manual.
http://main.experiencetherave.com/subar ... _diag1.jpg
http://main.experiencetherave.com/subar ... _diag2.jpg
Before tearing into the trans, I'd make sure the wiring is good as well.
You can remove the rear tail housing where the duty c solenoid is located with the trans still in the car. If you're tearing into the trans, it probably wouldn't be a bad idea to check and probably replace the clutch plates.
criticalm@ss
thanks buddy, i will be glad to ge tthis wagon driving the way it is suppose to be.
criticalm@ss
i unplugged fuse 14 yestrerday, should I plug it back in before starting or after?
Plug it back in before starting.
criticalm@ss
ok thanks, i need to do this soon.
I came across a hood same color and couldnt pass it up.
criticalm@ss
Ok so I am getting ready to purchase the duty c solenoid from the dealer? suggestions?
And how much am I looking to dump on new clutch plates?
