Ej20T heads on Ej22T Part 2
morgie
Post by morgie »
Whent to my friend this evening with my 2 short block halfs, to make another swap test just to make sure everything fits...
Conclusion :
EJ20T heads does fit well on the EJ22T block.
EJ22T Intake Manifold does not fit at all on the EJ20T heads.
EJ20T Intake Manifold fit and bolts perfectly on the EJ20T Heads on the EJ22T block
Pictures :
All the pics in hires (click the "get originaly uploaded photo" link under each picture)
http://public.fotki.com/morgie/morgie/o ... _on_ej22t/
Ej22T Intake gasket over Ej20T heads... You can see that nothing fit.. neither the side bolts, nor the center bolts... even the hole down fit.
Ej22T Intake manifold over Ej20T heads.. the side holes dont match.
On the other side, you can see that the manifold is about 1"1/2 too short
But, with the Ej20T intake, it fits and bolts perfect.
the Ej20T and Ej22T shortblock seems to be exactly the same in therms of dimentions. All the bolts holes on the front are the same too. I guess subaru produced only one mould ;) and re-used it to produce the different "sauces" of the ej engine.
morgie
'98 4Runner V6 Manual 4x4.
ciper
Post by ciper »
Morgie: I would paypal you the money to buy an EJ25 SOHC intake gasket from the dealer if you could check it against the ej22t heads if its not too much....
You need to edit your post specifially
"EJ22T Intake Manifold does fit at all on the EJ20T heads."
morgie
Post by morgie »
oups, thanx, i corrected it ;)
I'll stop at my dealer tomorrow to compare the 2 gaskets. They should have that in stock so it will cost nothing at all :)
morgie
Brat4by4
Stratified
Post by Brat4by4 »
Will you switch to coil-on-plugs or just custom mount your coilpack somewhere in the engine bay with that intake?
ciper
Post by ciper »
Brat4by4: When I was planning to do this I wanted to keep the centrally mounted coil pack and have Magnecore create some custom wires. That way I could also still use an aftermarket ignitor and diamond coil pack.
Morgie: Can you compare all three? EJ25 EJ20t and EJ22t? Then we can nail this all down once and for all. EJ25 DOHC and SOHC would also be cool.
It's pretty easy to make custom wires... you can reuse your stock boots and connectors in most cases.
morgie
Post by morgie »
Gasket bonanza ! hehe
1 - Ej22T and Ej22Na shares the same gasket
2 - Ej22T and Ej25 SOHC shares the same "overall disposition" of the bolt holes, but the holes dont match. Also, the intake port holes are bigger on the 2.5l (the same size as on the DOHC ones). The 2.5l gasket is wider than the ej22T
3 - EJ25 DOHC gasket looks almost the same as the EJ20T one of my friend. Would say i'm sure at 99% it's the same gasket.
4 - EJ25 DOHC and WRX Ej20T Gaskets are .. ALMOST the same. Bolts and intake holes are at the same place, the same size. But the tinny linup-holes are not at the same place.
Finally, I asked the prices of the EJ257 (2.5l STI) pistons... : 650$ CAD Each !!! compared to 80$ CAD for the EJ22T ones...
morgie
ciper
Post by ciper »
"tinny linup-holes are not at the same place."
Can you explain this more?
morgie
Post by morgie »
there is 2 spring pins in the heads that serves as guides to position properly the gasket on the heads... so it wont move while you install the intake manifold on them. Well, the holes for those spring-pins on the 2 gaskets are not at the same place.
I did a super mega exact drawing of that..
Assume the 2 gaskets are the same size. The holes where the arrow points are the ones i'm talking about.
http://themorg.dyndns.org/misc/gasket.GIF
2.5l = DOHC, 2.0l = the STI or WRX 96 head of my friend.
morgie
morgie
Post by morgie »
i just realise... you can see the spring pins there.. look at the lower part of the gasket on the picture.. you can see them
hirez : copy paste the url in internet explorer.
http://images4.fotki.com/v45/free/f2ee4 ... img-or.jpg
morgie
The EJ22 does not have these little spring pins......I sorta think the EJ22T doesn't as well.
BTW....Love the super exact drawing morgie :D
mTk
no title
Post by mTk »
The 22t does not have them.
mk
1992 BC672 AWD 5MT
morgie
Post by morgie »
Legacy777 wrote:The EJ22 does not have these little spring pins......I sorta think the EJ22T doesn't as well.
You're right for the pins, since the EJ22 and EJ22T shares the same exact intake gasket :) I think they also shares the same heads.
didn't you know i'm a professionnal artist / drawer ? :)
morgie
morgie wrote:didn't you know i'm a professionnal artist / drawer ? :)
How much for a professional portrait :)
FrmRgz2Rchz
Post by FrmRgz2Rchz »
EJ20T heads and the EJ20T mainfold bolt up which means we'd have the higher rev limit we'd get from the DOHC, the fuel system that can be easily upgraded, and a block that can handle a sh*t load of power?! This sounds like an awesome setup.
Do the heads flow just as well, well you know what I mean, as the 22T heads.
Also, would the integrity of the 20T head gasket in this setup equal that of the 22T's gasket on a stock setup?
Andy Rose
1993 Subaru Legacy Sport Sedan
2003 Subaru Impreza WRX
2004 Subaru Impreza WRX STI
1999 Hyundai Accent
morgie
Post by morgie »
FrmRgz2Rchz wrote:Do the heads flow just as well, well you know what I mean, as the 22T heads.
In fact, you should use the 22T head gasket with the 20T heads. But you get a crappy ~7.5:1 CR .
I'm buying for 1500$ CAN an SDS + EJ20G engine + EJ20T shortblock... and will see what i takes on it.. i would have loved to get the EJ20T intake... err.. nyway, that's a pretty good deal for the price.
Legacy777 : If you have to ask, then you can't afford it ! hehe
morgie
FrmRgz2Rchz
Couldn't I make up for the low compression ratio by turning up the boost to say....30 pounds? :D
Andy Rose
1999 Hyundai Accent
Sure, but it'd be a slug off boost, and a turbo that can pump 30 psi'll probably be off boost for an annoyingly long time when accelerating from a stop.
morgie
Post by morgie »
Like a fully upgraded Skyline GTR in Gran Turismo 1 .. hehe
I wonder how bad it will be at 7.5:1 ...
morgie
Brat4by4
Stratified
Post by Brat4by4 »
Nitrous is one expensive option to overcome any off-boost sluggishness.
ciper
Post by ciper »
What is this talk of compression ratios? Your going to be inside the engine anyways, why not do it right the first time and get pistons to match the head? Id assume you at least plan to replace the rings so the pistons are going to be out anyways.
morgie
Post by morgie »
Because i'm a poor lonesome cowboy ;)
morgie
ciper
Post by ciper »
I partially understand, but your 1000$ US piston set is not really the price you could get it for. I bet a set of 700 dollar pistons plus shipping from a Legacycentral users house would help....
morgie
Post by morgie »
are you planning to get such pistons ? cuz a "group buy" is often cheaper.. ;) i may know 2 other guys that could be interested too.
And for the piston being removed... maybe this picture will give you a hint :)
Mecanic ? I eat that for lunch ! hehe
http://themorg.dyndns.org/misc/mange2.jpg
morgie
ciper
Post by ciper »
Hmm, I was going to get a set and Nate from S-squared was also planning to get some. He has a hook up. What bore would you guys want?
