I rerouted my heater core line to help in the process of eliminating a overheating problem
and now I forget which line goes to what side.
Can someone post a pic of the lines going into firewall for me so I can have
Heat in my car again, Its freezing!
thanks in advance !!!
Need pic of heater core inlet/out
criticalm@ss
92 Leggy Wagon L~2003 Baja~2006 Sti
Re: Need pic of heater core inlet/out
You're talking about the two hoses that attach to the rear driver side of the engine, about 5/8" inner diameter? I don't think it really matters which you connect to which; I'm pretty sure I've done it both ways. Just hook it up whichever way seems to line up the best.
criticalm@ss
bump for a definate answer or pic.
criticalm@ss
bump, I know this is directional just want to confirm.
I know this is late, but the line coming from the coolant crossover is the inlet to the heater and should be on the passenger side, while the outlet from the heater is on the driver's side and goes to the water pump.
This pic may help.
http://www.main.experiencetherave.com/s ... G_3769.JPG
This pic may help.
