Ill look myself but I dont want to miss something.
By intake I mean between the throttle plates and the head. Ill start:
Throttle Position Sensor
Injectors and Fuel Rails
If your curious why I ask Im trying to figure out how to make everything from a Legacy Turbo fit on a 2.5l intake
Help me make a list of all items attached to the intake
Hmm, well, if I'm understanding the question correctly, here's what I can think of on the spur of the moment...
The intake manifold itself
EGR system (if applicable)
Canister purge control solenoid
All the fittings and hoses for vacuum accessories (pressure exchange solenoid, canister, brake booster, blowoff valve, etc)
IAC valve (I think the 2.5 has the IAC valve built into the throttle body)
PCV valve
So you're trying to use an EJ25 intake manifold with a Legacy Turbo engine? Which EJ25, and why?
PCV valve
the iac valve on 2.5 manifolds is on the ohter side of the madifold, dunno how much difference it'll make, my guess is he's goin with 2.5 heads.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
welcome
