Stock long block
VF 39
06 WRX TMIC
Yellow tops
JECS MAF
Robtune EJ20G ECU
AEM wideband
MBC
3'' Turbo back
Apexi Intake
Here's the link to my intro thread for the car, it shows the car when I started, the donor car, the swap and how it sits now.
http://bbs.legacycentral.org/viewtopic.php?f=9&t=46263
I played around with mounting my wideband recently. I wanted to mount the gauge on the steering column concentric with the tach, so I experimented with some materials I had at work to make a pod. There was some pvc caps, black delrin bar and a plastic gum container that worked surprisingly well.
I think the gum container was one of those 60 packs of Eclipse gum. I trimmed it down, painted it black and cut a slot on the back for the wires and bracket. The mounting bracket was from a VDO pod kit.
When I test fit it in the car I realized it was a little high for my taste, it sat right in the middle of the tach. I decided to try and mount the gauge flush on the column using a delrin cup. I made a simple cup from the delrin bar in a lathe, and turned the ID so the gauge was a snug fit. I through bolted the cup to the column cover using two socket head cap screws with a rubber biscuit underneath for damping (the biscuit is a trimmed down piece of my old IAC valve hose). Here is how it looked.
On my test drive the gauge shook like a bastard at highway speed. I had broken both the plastic feet that sinch the column cover down to the column. I trimmed them completely off and used some more of the IAC valve hose to make two little pads to let the cover sit right on the column. I drilled two holes where the feet were and wrapped a tie wrap around the top and through the holes that bolted the feet to the column. It wound up working great, the gauge was rock solid.
Here's the final product from the driver's perspective:
I should have plenty of updates coming soon, I just picked these up locally:
