Very Bad grinding noise, Video inside please help
okay all lets start, I was making a left or right had turn at low speed 5 mph or so as i was turnig it sounded like the axel popped out and it made a strange grinding noise. wile the car was still in gear it went to idle rpm around 500 rpm. When i put the car in neutral then 2nd gear i got grip again and was able to drive home. when i got home i tried to do the same thing. Taking the car to my storage untill i can find time to take it in i was in 2nd gear costing down and it popped out right after i stoped accelerating. I'm thinking it is the axel because it sounds like the little gears on your axel grinding and its only on the driver side of the car. but i'm no pro so thats why i will take it into the shop. unless someone can tell me what they think it could be or what i could look into. Hope i can get some help if not its okay, i cant really describe what is happening except the fact that its a grinding sound and its only on the driver side wheel area.
Then i tried this...
Okay so i jacked up the car and grabed that axel and was able to movie it in and out of trans(hope you know what i mean) and it was able to move about 2/8th inch. I was told that it should not move at all and if it does then i have a bad axle. I didn't have time to take it off but if you all think its a good idea then i will. IF you all have no idea and think i should wast my money giving it to a shop that will steal my money(lol) then i will!!
Hope this video will help you guys diag whats wrong.
http://www.youtube.com/watch?feature=pl ... 6sfCtwWa5Q
Thank you
Thank you
Greg
1993 Subaru Legacy L Wagon BJ6
2006 Honda Civic Si FG2
Re: Very Bad grinding noise, Video inside please help
Greg
replace it. see what happens. or pull it and scope it out. its a pretty easy job.
1998 legacy l wagon
1988 ford ranger prerunner (my baby)
1998 legacy l wagon
OK I'll post up pic/vids of what i findSUBYLUV871 wrote:replace it. see what happens. or pull it and scope it out. its a pretty easy job.
thanx
Greg
sounds like plastic rubbing. but if you pull the axle, theres a pin you need to punch out. in your red box the in that hole. i can do mine in about an hour or two, if everything goes well. good luck
1998 legacy l wagon
1998 legacy l wagon
SUBYLUV871 wrote:sounds like plastic rubbing. but if you pull the axle, theres a pin you need to punch out. in your red box the in that hole. i can do mine in about an hour or two, if everything goes well. good luck
Hmmm... PIN? not sure what you mean? any pictures? what red box do you speak of because when i was under there last night i didn't see anything red?
Greg
oh sorry. in this red box. the hole has a pin the needs to be punched out. keeps the axle from comming off the splines. hope thats helps.StreetLegacy93 wrote:
1998 legacy l wagon
1998 legacy l wagon
best i could find, this is off a 03 but same concept. #2 is the pin. #20 goes on #12 spray some penatrating lube and let it soak to break the splines loose if there somewhat seized. PB blaster i found works the best.
1998 legacy l wagon
1998 legacy l wagon
Greg
easy breezy. good job.
1998 legacy l wagon
1998 legacy l wagon
