Turbos?
J-MoNeY
Turbos?
Post by J-MoNeY »
I have no idea what you guys are talking about with your 16's and Vf stuff. I need some one to give me a rundown on what kind of turbos the EJ22T's have in them, and what kind and what are the turbos names of the kind of turbos that will fit on to our cars.
98 LGT
morgie
Post by morgie »
EJ22T = IHI VF11 with RHB5 turbine housing
WRX & STI 93-96 = Mitsubishi TD05-16G with a similar housing and 90° intake elbow as the VF11
WRX USDM = Mitsu. TD04-13G.. similar housing, no 90° intake elbow
STI 97 + = IHI VF ... 24 - 28, also aftermarket IHI turbos.. similar housing, no 90° elbow
morgie
'98 4Runner V6 Manual 4x4.
Worth noting also is that the turbos are clocked differently. The compressor outlet of the EJ22T's VF11 comes up at an angle about 45 degrees between the horizontal and vertical. From what I gather, all the others come up almost horizontal, maybe 10 degrees up.
morgie
Post by morgie »
yup, all the other turbos output is horizontal. VF11 is 45°.
but if you put a TD05 or other turbo, you ABSOLUTELY WANT to install an intercooler, so the horizontal output will match perfect with the intercooler input piping.
morgie
J-MoNeY
Post by J-MoNeY »
morgie wrote:yup, all the other turbos output is horizontal. VF11 is 45°.
So do you think a 16-g would be the best turbo for the money. I want to look at around 300 WHP.
98 LGT
rsstiboy
Post by rsstiboy »
I just purchased a MY94 JDM wrx half cut, with Blitz FMIC, TD05, Apexi injectors, and a conveniently programmed ECU :twisted: will send pics once its all installed in January, *welcome to the 12 sec 1/4 club!!* :twisted:
MY02 B4 Liberty, 2 1/2" off the primary with splitter, 3" off the secondary, 3" the rest of the way, completely stainless, k&n filter, ECUtek 3, 500HP walbro, 173kw@all4
ciper
Post by ciper »
So once this is installed what will you have left over?
kelley
Vendor
Vendor
Post by kelley »
the ihi vf23 is also a very nice turbo for the money. they are ballberring and will support up to 20 psi on your ej22t. I make full boost at 2500 rpm. they seem to be going for around 750 new.
rsstiboy
Post by rsstiboy »
ciper wrote:So once this is installed what will you have left over?
left over will be the std RS engine, water/air cooler, gearbox with 3.9 diff, VF12, standard exhaust headers, standard RS computer with chiptorque chip, actually now that I think about it pretty much everything is going to be swapped :twisted:
boostjunkie
Post by boostjunkie »
Would you be interested in letting that a/w intercooler go and the associated plumbing?
Now that I think about it, you'll probably have two a/w intercoolers at your disposal, since you'll most likely be using that front mount!!
ciper
Post by ciper »
boostjunkie: Hey, I saw it first!
rsstiboy: Let us know when you are done, we would love to gobble up your left overs.
THAWA
Post by THAWA »
send up some of the electronics (mirror switch/ fog light switch) and ill we can all be happy :D
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
rsstiboy
Post by rsstiboy »
boostjunkie wrote:Would you be interested in letting that a/w intercooler go and the associated plumbing?
I'll only have the one water/air cooler but I think it will go with the engine, there are plenty of people chasing complete setups for brumby utes and alike
That BRAT is insane! What I wouldn't give for a similarly treated 2-door GL hardtop!
ciper
Post by ciper »
Anyone help me to identify a turbo with markings:
VF 28601
RHB5 14430A
legacy92ej22t
Post by legacy92ej22t »
Well, could it be a VF28? I can't remember which version WRX/STI got it though.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
legacy92ej22t
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
legacy92ej22t
A ha! The VF28 is from the Ver. 5 STI. It's pretty much a VF24.
http://www.xxtuning.com/ihi/
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
ciper
Post by ciper »
ciper
Post by ciper »
Found another interesting one
SPEC-VF28507, SERIAL#- RHB51820A, PART#-14412AA002
I can tell its a subaru turbo from the part number. Subaruparts lists it as "Pt500291 Turbo Charg" with replacement part number 14412AA032
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 2460544282
legacy92ej22t
http://asp.turbo.com.sg/p_subaru.asp
http://www.mercurymotorsport.com.au/man ... turbo.html
http://www.ravensblade-impreza.com/parts/partswrx.html
Turbocharger: IHI RHF5 VF28 14412AA291 That's a listed part# for the VF28 on the above site.]
http://www.capa.com.au/turbo_bb.htm
There's a lot more out there too. I just did a search on Google for IHI VF28.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
ciper
Post by ciper »
You guys are sure its not just a coincidence that the numbers say vf28xxx ? These are surely vf28 turbos?
Would this be a VF26 then?
"Model VF 26194A"
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 2460474097
legacy92ej22t
That looks like a VF8 off a GL turbo or something. See how it only has 4 bolts for the DP instead of 5.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
legacy92ej22t
ciper wrote:Found another interesting one
Ya, I think both of those are off old GL turbo's or XT turbo's ect... That second one also only has the old 4 bolt pattern for the DP. They are probably old VF8's or whatever.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
ciper
Post by ciper »
How soon I forget that! So all three of these turbos are probably from the older generation, meaning 1.8 liter engines and low boost.
