EJ20G "RobTune" Info
Re: EJ20G "RobTune" Info
I would agree with that. I'm sure if someone did something off-the-wall, you might be able to get more, but that is most likely going to be an outlier.
I thought I mentioned it, but apparently I didn't. On that dyno a stock STi puts down 250/250 awhp & ft-lbs of torque. So I used that as a reference to compare my numbers to since the stock STi is rated at 300/300 chp & ft-lbs.
Hey rob, I'm a good friend of logan9691 and I want an ECU, just thought I would post here. Sent a you a PM too. Looking forward to hearing from you!
Can I just purchase the chip with the tune, since my ecu will have a socket allready.
93 Turbo Wagon, 5mt swap, vlsd, sti slanty, vf10, alk, subframe lockout, gr2's, sti sways.
96 F-350 CCLB Powerstroke
89 Volvo 244, lsx swap
Shoot me an email and we can work it out.DevC wrote:Can I just purchase the chip with the tune, since my ecu will have a socket allready.
-Rob
Hmmm, I just picked this up.... i wasn't sure exactly whom it originated from but now i read this whole thread fully, i'm not thinking its from you Rob.
would you be interested in it? would it help your cause? (i emailed you a pic as well, before i read this entire thread) Sadly i do not have much information about it. other than it runs ROUGH on an EJ20G
Vid
http://www.youtube.com/watch?v=FE0ObeH3 ... AAAAAAABAA vibrate and ring just before start is from phone. and there is a "Shit" in there for NSFW warning
vid of EJ20G ecu V5 (wrx wagon)
http://www.youtube.com/watch?v=5rCbGylL ... AAAAAAAAAA
Vid
would it ever be possible to run a newer style MAF sensor with this ECU?
VF43 custom FMIC APEXI intake Invidia 3" TBE JDM Ver. 4 RA STi trans (4.44) SPT short shifter rear LSD WRX rear axels coilover suspension JDM 4-pot front brakes drilled slotted rottors Greddy EBC tuned 20G ECU sti 550cc injectors Jecs MAF walbro 255
sent you an email about getting a retune today rob
ever? hmm, that is a long timelogan9691 wrote:would it ever be possible to run a newer style MAF sensor with this ECU?
-Rob
It'd be nice to be able to run a new style MAF since they make blow through tubes for it and would allow us to run VTA BOV. Or to find a way to mount the current style MAF (i.e. JECS) in a different spot.
What are the advantages to running the Z32 MAF?
The ability to measure A LOT more mass flow.logan9691 wrote:What are the advantages to running the Z32 MAF?
I see. What about upgrading the MAP sensor to run more boost?
The air sensor currently being used can't read over about 18 PSI so you're bottlenecked for fuel right there.
Yeah I know, but they make upgraded MAPs to read more boost.
The MAP and MAF sensors serve two different purposes. The MAF measures mass air flow into the engine. This is the basis for all engine "load" calculations and fuel calculations. The MAP is basically used for boost control and atmospheric adjustments.logan9691 wrote:Yeah I know, but they make upgraded MAPs to read more boost.
-Rob
Right. So what map sensor would be use if we wanted to go over the 18 psi level?rob wrote:The MAP and MAF sensors serve two different purposes. The MAF measures mass air flow into the engine. This is the basis for all engine "load" calculations and fuel calculations. The MAP is basically used for boost control and atmospheric adjustments.logan9691 wrote:Yeah I know, but they make upgraded MAPs to read more boost.
-Rob
Typically for my 550 tune I remove the boost cut altogether so the MAP sensor's limit is not an issue. Granted, it isn't an ideal solution, but it gets the job done.
Does mine still have boost cut, when i go over 18psi it'll cut out.
Yes, yours does because you specifically asked for it
gotcha. so would you be able to make it so we could run a different MAP sensor with the Z32 MAF so more boost could be run and still have the safety feature of boost cut?
Since we're talking about the z32 MAF, is there any glimmer on the horizon Rob? I know you've been working on it a long time. I've already scored one off an infiniti j30 just in case. lol
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
Oh, I see what you are getting at. Yes, I have spent a little time working that out. I have the code to adapt the EJ20K MAP sensor, but have not tested it. In theory I could adapt any MAP sensor if I figured out the volts to PSI transfer function and converted that into ECU speak.logan9691 wrote:gotcha. so would you be able to make it so we could run a different MAP sensor with the Z32 MAF so more boost could be run and still have the safety feature of boost cut?
Yeah, maybe a glimmerFlorin1 wrote:Since we're talking about the z32 MAF, is there any glimmer on the horizon Rob? I know you've been working on it a long time. I've already scored one off an infiniti j30 just in case. lol
-Rob
What about a 740 tune can u do that?
90 legacy Wagon LS Special, JDM closed deck 20g, custom 25d heads f/ metic motors, APS GC FMIC, 740cc, VF34, 4.11 F/D, Turboxs RFL blow off valve, now with piggyback.
94 Legacy SS R.I.P (parts car now for 90)
97 Legacy Outback (sold)
Hey Rob, i emailed you about a week ago, i'm ready to purchase an ecu to get my new project up and running.
93 Black Legacy SS
93 Legacy
97 Green Outback
97 Red Legacy GT
99 Black Legacy GT wagon
93 Legacy
97 Green Outback
97 Red Legacy GT
I was told you are the one to talk to about ECU tuning. I have a 93 legacy SS. Was a EJ22t stock. Then got swapped to JDM V1 STi engine, same ecu. Now I am putting in a VER 3. Specs- MGF date 02/07 EJ20k Type RA/STI 4.44 DCCD tranny. Ready to move on this right now. Engine is on its way and I would like to send my ECU to you if you can work it. Let me know, thanks.
