phase 1 closed deck ej20 block with oil squirters, moly coated pistons, nice cross hatching, forged bottom end, balanced and forged crank - $700
magnesium long runner intake manifold - $1000
VF10 turvo without the wastegate crack or shaft play - $250
2 sets of RS/RA Heads that came hand ported from the factory - $100/head comes with all hardware
multiple 10mm oil pumps - $75
hundred+ oem Subaru gaskets, bearings, timing pulleys (probably about $250 worth)- Offer for the whole box
badass machined aluminum dry sump setup, I just don't have the actual pump. - $400
post questions if you have them. Much more to come as I am trying to clean out shop.
Sweet. If they pan out, I'd be in for a set of RS/RA heads.
Off to NastiCock......
Too bad it doesn't look like those heads come with cams. At least I didn't see them in the pictures.
