I know I'm a bit overdue on an update for many of you and rather than clutter the sunroof thread I thought I would make a new post.
Mod's, please feel free to let me know if I'm cluttering up the Vendor Forum un-neccesarily.
So where to start. Things have been exceedingly busy since the start of Nov. There have been some critical issues needing addressed with some of my consulting clients and there have been some family emergencies requiring immediate attention. Mix in the holiday's and it's been tough make the forward progress I'd hope for at the shop.
However, I have been working with my new epoxies - my old vendor is going to be out of the picture for a little while unfortunately - and the new systems are working fairly well. Unfortunately, I have been having a little difficulty getting the surface hardness and transition temperatures I want with just the room temp cure. Now that winter is here I cannot get my heat room up to temp without installing permanent insulation and top on it. I cannot add the top and insulation until I get new sprinkler heads installed.
This has led to building plans, sprinkler plans, permits, etc. etc. Getting the permits and people required in place during the holiday's in an expedited time line has been a little difficult. I don't know how many people here have dealt with commercial building expansions, or even residential, but if you have you probably understand where I'm coming from...
That said, I have an appt. on Jan. 6th to meet with my building inspector to discuss a few items and finalize the permit. From there I'm a couple weeks until I have the sprinklers installed and my heat room back up and running.
This pushes the schedule well outside my plans but does have potential for some strong benefits. Primarily, as I work with City Hall I may infact be able to turn my heat room into a 300 deg. F curing oven. This would provide my customers with a much stronger and durable product without affecting price. I have plans and am working with a fabricator to get my higher temp oven, 5' x 3' x 2' and 450 deg. F, up and running by the end of Feb.
In the mean time I have added a 250 sq. ft. mezannine for storage of molds, added some dust/particulate managment equipment, and rebuilt my vacuum pump for greater capacity. I have also formally started a post-face lift hood mold. I will get a formal hood thread started after I get back from the holidays and can provide a few pictures. Long and short is that it will create a hood with an integrated scoop just a hair taller than stock. However, there are inserts I will build to allow for a hood with no scoop or a recess for a WRX, RS, etc. scoop to be bolted on.
So there you have it. It's a bit more of an update with some finer details than I'd normally give but I know many people have been patiently waiting for all of this to solidify and felt you should know where things really are at. I know my schedule slides have impacted the schedule of a few folks I've talked with via PM's and the phone, but I'll be in touch shortly with parts and a deal to make things right for you
Please feel free to ask questions, offer up comments. I'm here to support the BBS and welcome the various ideas I've been receiving.
Thank you,
Lee Skidmore
Owner/President
Lee@NorthwindComp.com
208-290-5585
