Looking for 250hp @ the crank. What to do?
'93_5SPD_TURBO
I'm looking for some help with mod ideas. In the near furture I want to start putting mods on my '93 Legacy Turbo and reach 250hp. What mod combo will best get me there?
Thanks for all the help,
LegacyT
There are two ways:
Stock Turbo:
Boost, EGT, fuel pressure Guages
Intercooler, Saab 900, WRX Old or new Generations
Exhaust- 3" all the way (Turbo back)
Larger fuel pump - Walbro 225Lph
Somesort of fuel-cut denfender
Boost controller - EBC or MBC and boost to 15 psi.
Though with some engine management you wont need a fuel cut defender or a boost controller
That should get you pretty close to 250hp - BUT
that is maxing out the stock turbo, and doing so It probobly won't last very long.
A more costly, though more effective manner may be as follows:
New turbo:
Intercooler, Saab 900, WRX Old or new Generations, or even front mount.
Larger injectors 440cc old WRX side fed ones are good
AND a larger turbo - TD05-16G from a early wrx is good, don't bother with the current WRX one, it is only slightly larger than ours. Then there is the whole IHI VF series which I would have to find out more about.
That will get you 250 hp easily without an aftermarket ECU. With one though you'd have a very very powerful engine
Mark,
Stock Turbo:
New turbo:
Mark,
boostjunkie
boostjunkie
boostjunkie
You seem to be more into the "proper" method of tuning (standalone vs. piggybacks) . . . that's all.
It's envy, really . . . I wish I could afford one of those standalones
boostjunkie
You'd need a S-AFC to lean out the A/F mixtures, since for every injector pulse, the engine would be receiving more fuel.
boostjunkie
