Joe's 1992 Legacy SS/TW Documentary
Re: Joe's 1992 Legacy SS Documentary
Info is on my swap write-up
http://www.surrealmirage.com/subaru/swa ... l.html#ecu
Let me know if you still have questions.
CAV3MAN227
Post by CAV3MAN227 »
-Thanks Josh. I'll let you know!
-Done some more work to the car, putting it all back together interior wise. Also put on some Legacy badges since mine didn't come with them.
-Joe
CAV3MAN227
-Installed my td04 last night!
-Really liking the difference!
-Joe
CAV3MAN227
-Thought this looked cool! Crazy sky in Denver, Co tonight!
-Joe
CAV3MAN227
-Well I've been dealing with this code 24 problem, it feels like for a month now, and I have had it!
-Thread here: http://bbs.legacycentral.org/viewtopic. ... 50#p341150
-I also found this black wire that looks like it was cut... it comes out of the fender, in the whole loom, underneath the fuse box and it carries power when the ignition is on. I have no clue what it goes to. I'll have a picture of that up tomorrow!
-Joe
CAV3MAN227
-So here's the pic of that wire I was talking about: http://hostthenpost.org/uploads/72b29c3 ... e67afa.jpg
-That wire has ignition power and have no clue where it goes!
-Joe
CAV3MAN227
-No worries on that back wire. Someone before me tapped into the red wire to power something lol! Still have code 24 and 49 laying around to kick out so I don't have a CEL!
-Joe
CAV3MAN227
-Today I checked my spark plugs:
-Passenger side closest to radiator:
-Passenger side closest to firewall:
-Driver side closest to radiator:
-Driver side closest to firewall:
-I'm getting a code 41 now and don't know why, so I started here! Any ideas or need to know anything please let me know! This is a different ECU (automatic), not my original manual ECU, that this code is coming up on. This code did not show on my ECU. I'm using this ECU for now till I can find another one for me.
-Joe
It shouldn't matter that the ECU is from an auto car. The turbo legacy ECU's should all be the same. Have you tried running the d-check mode to see if anything comes up?
CAV3MAN227
-All that comes up in d-check mode is code 51 and 52, nothing else.
-Joe
Hmmm.....can you get the part # off your old ECU and new ECU and post it.
CAV3MAN227
-This is mine, the one I'm not using right now:
http://hostthenpost.org/uploads/a9e25a9 ... de019f.jpg
-This is the donor that's being used as of right now:
http://hostthenpost.org/uploads/e233a1c ... 4cd0a2.jpg
-Joe
Hmm....yeah those ECU's should be swappable without any issues.
I don't understand the code 52 since it's a 5spd. Is the TCU still in the car?
CAV3MAN227
-Well the car was originally an automatic. Someone before me did a swap.
-I'm not sure what the TCU looks like so I'll get a picture and get back to you on that. But from my knowledge, it is probably there cause the TCU is where the ECU is getting code 51 and 52 from.
-Joe
Here's a pic of where the TCU is located. Codes are only from the ECU.
http://main.experiencetherave.com/subar ... cuhide.jpg
goderd
Post by goderd »
Nice build Joe, keep it up :)
CAV3MAN227
-Its been a while for an update and sorry for that.
-About the IAC, it turned out to be the ECU the whole time. So I got another ECU and the car has ran fine ever since. My last little problem still is idle. When warm idles around 1000 rpms. I's like it to be normal... must have a vacuum leak some where lol! Its been a long time since I've seen a CEL and so happy for that!
-UPDATES: I might repeat a little... but i now have RS rims on the 92 SS, TD04, turbo xs dual stage MBC, still have the avcr hooked up to the ECU cause it gives information but vacuum is all disconnected, different exhaust to bring out that subi sound and i think thats about it.
-I'll get some pix of it up real soon!
-Joe
CAV3MAN227
-Here are some pix:
-Joe
turbo_meow
Post by turbo_meow »
word
Pics no worky
CAV3MAN227
-Sorry for the broken links. Its been a while since I have updated this, so I have taken some pics and I'll explain what has changed since my last postings.
-Here is me putting on a better fitting TMIC till I go FMIC:
-After:
-Getting an axle fixed at Slodrive:
-After polishing up the headlights:
-Random pics:
-I went from the dual stage boost controller back to stock for quite a while. Just recently I purchased a MBC to go along with my FCD. I was getting sick of the rattles the 02 TMIC was giving me, so it dawned on me that a friend went front mount and I knew he had the smaller TMIC, so luckily he still had it so I purchased it off him. Painted my center console a few days ago, got bored trying to find out why my sub stopped subbing. I'm sure I left a bunch of stuff out but thats all I can think of at the moment.
-Joe
CAV3MAN227
-I also made a quick video of my car:
http://www.youtube.com/watch?v=IbmUQQMO ... ature=plcp
-Joe
SiCkSTi04
Post by SiCkSTi04 »
Sounds and looks great, just be careful in the neighborhood :)
91legacyawdturbo
Post by 91legacyawdturbo »
^ yeah especially in my Neighborhood Joe, what the hell!
Oh I see my car or atleast it's butt haha
2002 wrx sport wagon
CAV3MAN227
-sorry but you were driving sir lol
-Joe
