I'm still debating using Monstaliner bedliner for the whole car or just for underneath. I'll have to see what funds will allow.
I got the car on the road today for the first time. Halfway through my trip the IACV hoses popped off because I didn't clamp them. I fixed it with some zip ties and will be replacing the zip ties with metal clamps tomorrow.
On the last leg of my trip the check engine light popped up for a code 32. I'm pretty sure the o2 sensor has had it's day in the sun and will need to be replaced. I'm thinking of grabbing a 4-wire bosch 15729 so I won't have to worry about grounding the signal through the exhaust. I'll probably try to ground the current sensor and see if that solves my problem while I wait for the new one to arrive. I've been thinking the exhaust isn't providing a good ground.
If that doesn't work I'll pick up a 1-wire sensor from autozone for 17.99 to drive around on for a few days.
I really only need to sensor to get rid of that annoying check engine light and to pass emissions.
There seems to be a wheel bearing issue on one or 2 wheels. It happens on right hand turns from the drivers side front. I have an extra wheel bearing and will be ordering another for the other side. I'll probably cheap out and buy a prime choice wheel bearing off of ebay for $25. It's a shame because they used to be $13 each.
The car itself is running like a champ considering it was sitting for 5 years. The forester engine was only sitting for a year.
We got tons of strange looks driving it around today. It seems that fire chiefs watched the car closely...maybe the flat black makes it look burned?
A sf forester owner did a double take as he drove by....my legacy wagon was taller than his "suv"....we had the same wheels too! LOL. I'm pretty used to driving low to the ground, so it was interesting for me to be taller than some trucks.
I received my toggle switched and installed them into my broken panel. They aren't wired up yet, and I plan on making a aluminum panel to fit them into. I can't wait to have power mode and a locked duty c solenoid.
![Image](http://i121.photobucket.com/albums/o232/deadhp1/94_legacy/IMG_20120326_145258.jpg)
![Image](http://i121.photobucket.com/albums/o232/deadhp1/94_legacy/IMG_20120326_145311.jpg)
The tape is there to hold the panel in place as the clips were previously broken.
I ended up putting my mismatched 215/60/16 forester wheels/tires on the car(one is a 205). The car did quite well and has a ton of power. I can spin it on grass and gravel. On the street it easily breaks the fronts loose till the rear catches.
It's in need of an alignment and matching tires badly.
I haven't heard a peep from the seller of the 17" forester tires or from the person selling the 15" general grabber at2's(215/75/15). So I've continued looking for tires.
I have found a set of 215/65/16 2009 forester tires for $75 that I will be trying to get over the next 2 days.
The brakes felt really weak the other day so we greased them today and sanded the scum off the rotors.
I have a set of wrx front brakes that were recently rebuilt and a set of h6 rears that are in need of a rebuild.
I might get around to putting them on soon.
I'll also be taking out the fuel senders soon to clean/replace them if needed. They read from full to half, then go down to empty. I was going to take them out the other day, but when I opened up the access plates I was greeted by one broken stud/missing nut and the rest of the studs looked quite weak. I guess someone else had the same idea before.
I'll be soaking them over the next week and will be running a die over the stud tips before even attempting this.
I found the rivnut tool and replaced the one spinning rivnut in the roof so I could put the roof rack on again. It worked like a charm.
I'm still debating keeping the stock roof rack or using the roof rails from the 2000 legacy I have. They look like they would fit, but I'd have to get the headliner out to be sure. They have studs coming out of the rails and are bolted in from the bottom. I'm also missing the crossbars for the 2000 legacy so I'd have to remount them to 2000 shell and secure it with wood before installing to the 94 legacy.
The forester roof rack is about 2 inches too wide to fit on the 94 legacy roof properly. It's a shame because I have the rails for that.
That's about it for the next couple of days. I'll grab some more pics soon!
I need to redo the brakes, wheel bearing, and o2 sensor on my wife's cobalt tomorrow. Then I can dig back into the legacy.
