squeeky suspension help
91scoobiesubie
today my car started squeeing when i went over bumps and also when steering.i pushed and pulled on each corner of the car and only the driver side s front squeek sounds kinda like rubber squeeking. nothing looks like its rubbing.possiblystrut?will any other subie strut match ours? also does any one have apart number for kyb's? thankyou
Have you by any chance fitted new bushes of any kind as I had a simiar problem on a golf when I swapped the anti roll bar (swaybar to u) drop link bushes and didnt do one of the bolts up properly, give all the bolts in the area thats squeeking a good torque up as it can be hard to tell wether theyve been done up properly.
If only I hadnt bought the bike, this would feel fast :P
I'd suggest the same thing - I replaced the two front antiroll bar links and eliminated a squeak and light knocking sound I was getting.
