Anybody have an ABS ring, spare they can sell me
Aeryck
Post by Aeryck »
I am having a helluva time finding it. Please let me know asap
Re: Anybody have an ABS ring, spare they can sell me
Moving this to the parts shed.
What is an abs ring?
93Leg-c
Post by 93Leg-c »
I believe he's looking for the toothed-ring that's attached to the hub.
'94 TW
Oh I see. I might have one. Maybe. Ill have to look at my moms when I go over there weds or thurs.
oldscoobyturbo
Post by oldscoobyturbo »
I have a parts car so I have one forsure
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
Aeryck
Post by Aeryck »
Actually, I prefer the whole pass side assembly as mine fell off where it tied up and was moving freely on the highway for a hour. I am going to assume it's damaged. I will pay 35 bucks and cover shipping for the whole unit or find one locally in a junkyard. Whoever get's to it first has it. Thanks guys.
oldscoobyturbo
i can pull the whole ring assembly to save on shipping weight. pm your email i can send pics
ciper
Post by ciper »
In case anyone cares they are referred to as a Tone Ring and the wheel bearing has to be replaced if you want to remove this,,, unless you do what I did and cut it in half.
I ran with a two piece tone ring for years without issue. Just make sure you cut it in a valley. I also found that non ABS hubs dont have the mounting holes drilled so at one point I had to weld the tone ring to the hub. I also ran that way for years without issue.
Here's the one I have. I tried installing new wheel bearings in my hubs and could not get the race pressed back in enough and it wouldn't seat properly without it going in that extra mm or 2 so I just replaced the whole hub assembly.
oldscoobyturbo
I have one here is a pic
Yours looks like the ring is way further in than mine. Why is that?
