coolant leak while idling?
Gang -
If I let my 93 turbo idle for longer than normal (~10 min), I get a small puddle of coolant (between the size of a quarter and half-dollar) under the passenger side bank of cylinders, towards the front of the engine.
My guess is the water pump, but I'm wondering why it only does it when the car is idling. Any input would be welcome. TIA.
2004 STi
1993 Touring Wagon
1993 Touring Wagon
you sure it's from the engine.
check the front portion of the plastic end cap on the passenger side. it's a common point of failure.
aluminum radiators typically have plastic end caps on them that are clamped on to the aluminum part.
Over the many heat cylces that occur, a small crack can form and leak coolant....my car had this same issue......I'll try and find a pic of it...assuming i took one.
also the waterpump is on the driverside so I don't think that's leaking
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
here's a pic of the radiator. the place that often cracks that josh was talking about is the part outlined in red. you can see that i put JB weld on mine and it worked for about a year and a half. but if i were you i would just get a new radiator if it is cracked.
http://www.angelfire.com/alt/subaru/images/radiator.jpg
Andrew
Andrew
209,000 miles!
2002 Impreza WRX Sport Wagon
209,000 miles!
hehe that's where mine cracked
either there or on the side facing the engine
