Oil leak at drain plug... crush washer?
91Beater
Post by 91Beater »
I let Jiffy Lube change my oil a few months ago and its been fine, but the other day I find oil drips under the car. I tracked it to drain plug.
How often is the crush washer supposed to be replaced?
rallyak
Re: Oil leak at drain plug... crush washer?
Post by rallyak »
I've never changed mine in 470,000 miles but I know others have.
Charles
It supposed to be replaced every oil change. That's why they give you one when you buy a filter at the dealer. Crush washers are not meant to be reused. You can do it but you run the risk of a leak such as you have.
91Beater
Post by 91Beater »
Is there something Subaru official that says so? I need it to take to Jiffy Lube and hope they'll fix it. If it's factory required procedure, then they had better get it done.
There is nothing written in the factory manual about replacing it. The dealer may be able to give you something, but I kind of doubt it.
It's one of those general common sense things most mechanics know. Sometimes you can get more than one change interval out of a crush washer. The fiber ones tend to do a little better with multiple changes.
You crazy trusting jiffy lube with your car. Go to the dealer or parts store and get a new crush washer or better yet a bag of them and quickly replace it yourself and top off the oil.
jp233
Post by jp233 »
I've had the same washer (its more like a soft paper/rubber gasket material) on one of my cars for 6 years and over 70,000 miles.... never a drop of a leak.
The 2006 GT we had, leaked immediately after the dealership changed the oil when we bought it, as they re-used the metal crush washer.
It's not a special part, you can find something usable from the parts store.
I also, have not trusted Jiffy Screwed with any of my vehicles in a long, long, long time.
12 Outback 3.6R Limited
94 Leg LS wag AWD, sold
93 Leg L wag FWD, sold
06 LGT 5EAT, project
