Current Mods:
Engine-
Oil changed every 2-3k with Mobil 1 synthetic ALWAYS
06 wrx tmic plumbed to oem STi bpv/APS 50/50 recirc and quality silicon piping from siliconintakes
TD04 freshly rebuilt
DEI turbo blanket(can touch it after running easy or hard forever!)
WRX metal coolant tank
TBE Invidia catless DP, w/Q300 catback
Custom intake and coffee cup mod
Hallman pro rx manual boost controller
STi motor mounts
Walboro 255 fuel pump
Optima yellow top
SPT blue battery tie down
Perrin oil catch can
Exterior-
Enkei gold rally rims 15" RCG4's
Hella horns (118dB)
Red rally armor polyurethane flaps
Black extended open lugs
Black 02 wrx scoop
Plasti-dipped back center garnish-(euro look)
15% tint all around
Wilwood 4pot front bbk (not installed)
Suspension:
04 wrx wagon struts w/ Eibach lowering springs (no saggy ass)
Interior:
Propost Halo electronic boost gauge w/altitude compensation, boost peak, warn mode, boost memory
AEM wideband uego gauge
12" Rockford Fosgate P3 w/Jensen 2000w mono amp
Upgraded aftermarket speakers front and rear
Oem manual black trim to match
06 wrx oem shift knob
Drivetrain-
93 Tleg manual swap with oem exedy wrx clutch kit
Extra-S gear oil
Kartboy shifter bushings (both)
93 Tleg 3.9 rear diff
Repaired list within ownership:
4 broken wheel studs
Engine bulkhead wiring harness
Intake manifold harness
Ignitor insulation and relocation
Timing belt
Valve covers
All braking components
All vac lines and hoses replaced/upgraded
All timing and spark components
Replaced shot suspension with upgraded wrx
New spark plugs
New upper and lower rad hoses
New coolant temp sensor
New Subaru oem thermostat
New drivers side wheel bearing+hub
Sanded/painted wing and hoodscoop which were peeling/faded horribly
To-do list:
5sp swap(once my auto goes)-done
Bigger injectors+engine management
FMIC swap
WRX seats(the nice black ones from 04-05)
Full plasti-dip paint job
When I first picked it up:
![Image](http://desmond.imageshack.us/Himg337/scaled.php?server=337&filename=78621389.jpg&res=landing)
After a wash and taking the janky-ass scoop off:
![Image](http://desmond.imageshack.us/Himg215/scaled.php?server=215&filename=56089898.jpg&res=landing)
![Image](http://desmond.imageshack.us/Himg521/scaled.php?server=521&filename=33259712.jpg&res=landing)
![Image](http://desmond.imageshack.us/Himg171/scaled.php?server=171&filename=90017008.jpg&res=landing)
Under the Hood:
![Image](http://desmond.imageshack.us/Himg835/scaled.php?server=835&filename=26309423.jpg&res=landing)
