I've been looking for a nice flat red to paint various engine parts with, and that has proven to be quite difficult. I've been through about 4 different reds and I finally decided to settle with this VHT Flat Red stuff, which is near impossible to find. I wanted to do wrinkle red, but I don't want to have to use my oven to cure the pain, my mother would ring my neck...
Been using my coolant crossover as a "test" part for all the colors. This will be the fourth type of red it has seen (all the other reds were too glossy) and I am going to stick with this color.
I plan on painting the intake manifold, throttle bodies, valve covers, and fuel stacks this flat red.
Various brackets and fuel rails/lines will be painted black.
Since I will be painting a lot of stuff while I have everything apart, I have been prepping the living snot out of everything I plan on painting. Piss poor prep produces piss poor performance, especially with painting, so I've been wire brushing, cleaning, using a small wire wheel with the dremel to get every particle of dirt off of everything. Didn't feel like taking a picture of everything prepped so far, but right now I'm cleaning off my fuel rails and lines.
Valve covers and throttle bodies have been prepped, now I just need to prep the intake manifold which should take a generous amount of time because it is rather big. I also need to buy more paint, I'd hate to run out halfway through laying down coats...
The heads are being shaved right now as I type this, so once I get them back, I will be re-assembling the heads, throwing them on the block and I should pick up a lot of momentum with this swap at that point.
