RHD swao wiring
BoostedSubie
RHD swao wiring
So, i've been tackling the wiring on my RHD swap this weekend and it has been overwhelming. First of all, all wiring harnesses are from a 93 Legacy wagon AT, no sunroof and it now sits in my 93 Legacy Sport Sedan MT with a sunroof. My problem is that the tail harness is obvisously different as I am using a wagon harness in a sedan. I went and got a sedan rear harness to try and make it work but the plugs that tie into the bulk front harness are totally different. Also, I want my sunroof to work but haven't really jumped into that yet. I'm getting to the point where I'm about to bag the RHD swao and return it to normal. I can't seem to find too many good wiring diagrams of the tail harness or the sunroof one. I will continue searching but if anyone knows where to find something, that would be nice.
93 Black Legacy SS
93 Legacy
97 Green Outback
97 Red Legacy GT
99 Black Legacy GT wagon
93 Legacy
97 Green Outback
97 Red Legacy GT
BoostedSubie
Re: RHD swao wiring
Also, it looks as I will have no heat in the car as the heater core I got with the heater suitcases is bad and the only heater core I could find for the RHD is $300 used and the RHD and LHD heater cores are totally different.
93 Black Legacy SS
93 Legacy
97 Green Outback
97 Red Legacy GT
93 Legacy
97 Green Outback
97 Red Legacy GT
Re: RHD swao wiring
The wiring diagrams in the factory service manual are quite good; you might try to get your hands on that. What you want is section 6 of the 92 Legacy manual. Section 6 is the electrical section and very little changed from 92 to 93. The part number is MSA5T9209A.
BoostedSubie
Re: RHD swao wiring
Ok, I think I actually have the factory service manual somewhere. Hopefully the lhd is similar enough to the rhd harness to make sense of it. There are a couple things I already noticed were different such as the rhd doesn't have the power seatbelts.
93 Black Legacy SS
93 Legacy
97 Green Outback
97 Red Legacy GT
93 Legacy
97 Green Outback
97 Red Legacy GT
Re: RHD swao wiring
If there are any differences between RHD & LHD it should be noted in the factory manual.
