^check for air leaks.
-Joe
Cheap FCD
CAV3MAN227
Re: Cheap FCD
Re: Cheap FCD
the bucking could be a number of things. Could be a fuel pump not being able to deliver enough fuel, or a poor fuel filter, maybe even an injector that's getting worn out.
keithmoilanen
Re: Cheap FCD
I hate being a damn noob with this shiout
2018 WRX
1991 Legacy Turbo
Sold 1989 Lifted Wagon
Sold 1987 Wagon
1991 Legacy Turbo
Sold 1987 Wagon
Re: Cheap FCD
Try turning the boost down and see if the problem goes away. If it does, you know it's related to turning the boost up. If the problem does not go away, then it could be a vacuum line or something non-higher boost related.
keithmoilanen
Turbo_Carl
Re: Cheap FCD
Thanks for the parts list! I just made one myself and it works great!CAV3MAN227 wrote:-So here's my setup. I went to Harbor Freight and picked up these items:
-1 #68198 1/4 x1/4 male-male coupler
-1 #68220 air inline regulator
-2 #68209 air brush adapter
-From auto zone I picked up:
-1 #47311 3/16" vacuum restrictor
-1 #47149 vacuum check valve (not used yet)
-My current setup:
1993 SS. 5MT, STI Fuel Pump, Custom Intake, Diamond Coil Pack, Forge BOV, Hallman MBC, Custom AWIC, CNT 3" Downpipe, SLP Resonator, Carbon Muffler, TD04, FCD
1987 Ford T-Bird Turbo Coupe (Pikes Peak Hill Climb Car)
CAV3MAN227
Re: Cheap FCD
-No problem. I have since, ditched that setup and got my hands on a fuel cut defender. 15psi on a normal bases... except when my crappy clutch slips
-Joe
-Joe
Re: Cheap FCD
back from the way dead lol. i tried this with the 2 way check valve and it has a light hesitation then goes like heck on 14 psi. or should i try the on way check valve i just want to be at 14 psi
