I have an EJ20R Throttle body for sale, make me an offer. You'll have to call me tho since my internet access is limited at the moment. 253 332 8158 It's for a 3 PIN TPS tho.
If you have a TMIC and are able to make the TPS work, this'll help with install and clearance issues at the firewall.
The tps for that is not compatible with our harness/ecu, correct?
