86 Subaru Leone
bmxkelowna
Re: 1986 Subaru GL-10 Leone TURBO
Post by bmxkelowna »
how did you fit it in the tunnel without cutting it up? both my room mate with a 83 2dr gl and regan who has the sti swapped 78 brat had to cut them up to fit there 6mt's
NICO
Post by NICO »
bmxkelowna wrote:how did you fit it in the tunnel without cutting it up? both my room mate with a 83 2dr gl and regan who has the sti swapped 78 brat had to cut them up to fit there 6mt's
Well from talk to the guys on Usmb they said some cars late model 1986 85 84 and older didn't get the bigger tunnel. I guess some how I got the bigger tunnel maybe for auto tranny.
Also I did shim the cross member with forester Xt shims subaru makes to get it a little better angle down more. I cut the shims to a inch thick for a better angle or else it still would have fit ok. Just a little safer now and I got lots of room up and down now.
I could shim the xt6 cross brace a bit but it sits perfect now.
NICO wrote:these pump push fluid so i think we might be ok, it also sits lower then the top of the level.
You'll still probably some issues priming the system, but you should be able to get it going.
I've drained & filled my awic system several times, and every time I wish I would have put a bleeder screw on the top of the front exchanger :)
NICO wrote:rear mustache bar is ready...
I love that name...haha :lol:
NICO
Post by NICO »
what about with the funnel thing ? to bleed the rad you try that ? i have a rad cap on my set up way up top.
LOL haha
well this is the tie rod problem taken care of, its simple and works perfect like !
top is xt6 legacy impreza
middle gl-10 turbo
last is whiteline new style
what you do is chop the end off so you can toe in the car like factory !
light weight knuckles ! top secret so the competition dont know !
4pot ready for action ! brembos maybe in the future but who cares really when your going to be this light and fast lol
rear just started so sunday all done.
the rear suspension is all old school up top and coilover down town, ill show how i did it very easy to do and keeps all the oem rubbers for when i pick up the ladys and its a nice soft ride !
HeLLaFLuSH for all you pimping OG's out there !....... these wheels are just to roll it out the shop on monday ! i like to go HELLaFAST LOL.
bed time
wow that car looks great. I admire your work and I hate you all at once.
NICO
Post by NICO »
kimokalihi wrote:wow that car looks great. I admire your work and I hate you all at once.
ya so far its looking good, thanks for the compliment & lol i guess :D
Haha you're welcome.
NICO
Post by NICO »
kimokalihi wrote:Haha you're welcome.
:D
NICO wrote:what about with the funnel thing ? to bleed the rad you try that ? i have a rad cap on my set up way up top.
The problem is in how the lines going to the pump are filled. If you fill the system via the AWIC core coolant will flow down in the lines, both suction and discharge, and an air bubble will form. When this gets to the pump, a standard centrifugal pump will just not work unless it is self priming. What I did to try and eliminate this was just fill up the lower part of the AWIC system via one of the coolant lines. This helps minimize the chance of an air bubble forming.
Since you have your pump up high, the system may fill from the one side vs. both sides at the same time, which may eliminate the problem. You just have to give it a shot and see.
BTW, the car is looking amazing as always. That thing is going to be such a sleeper! I think the 4-pots with good pads should be plenty sufficient. The brembos & larger rotors are just going to add weight.
Yeah, if anything, you'll need to keep some sticky rubber on it to prevent it from locking up too much. Oh, and to use all that power to move rather than make smoke. I don't think brake fade would be a problem with so little weight, either. It's amazing how good that looks. It looks like you're building up a car that's only a few years old. I had two of the EA81s and I can say that even just 10 years took a real toll in corrosion, so I don't know how that looks so good. If you plan on driving it in the winter, I recommend undercoating the hell out of everything underneath.
FundamentalyConfused
Post by FundamentalyConfused »
He's up in Canada evolution. They don't use salt on the roads up there. No rust belt like we have in the states.
1999 Forester S 5MT 200,000 miles and counting.
1990 Legacy L Sedan AWD 5MT Retired at 369,471 Miles
They don't use salt around here, either. They use sand, which is a lot better (I went to school in Detroit, so I could see the difference first hand as well as gain an appreciation for a state inspection process that I had seen as an annoyance until then), but still doesn't get along with steel. Undercoating with touch ups for whatever gets worn off every year and keeping it clean by blasting out the undercarriage frequently during snow season goes a long way. If they use something better than sand, I have another reason to think about moving to Canada.
evolutionmovement wrote:...and keeping it clean by blasting out the undercarriage frequently during snow season goes a long way.
This is the biggest and BEST suggestion to improve the corrosion longevity. The sand and dirt trap moisture against the body, which over time will promote rust and further corrosion.
Cleaning all that crap out regularly is very important. The 06 Legacy I had bought is a good example of that. I cleaned more crap out from the fenders....
keithmoilanen
Post by keithmoilanen »
Rain! Always cleans my car lol
2018 WRX
1991 Legacy Turbo
Sold 1989 Lifted Wagon
Sold 1987 Wagon
Yeah, one trick I used was to blast the high pressure hose at the base of the fender behind the front wheels until the water coming out by the door stopped coming out with sand in it. I spent more time on the undercarriage and wheel wells than the top side and the car is in remarkably good shape rust-wise.
brando
Post by brando »
Awesome..... Truly Awesome.
1998 GT
1994 GT
NICO
Post by NICO »
when i fill it up will see what happens, i hope it works out just perfect like how you say its up high but will see soon !
glad you like it and ya the brembos i think wont happen ill tray and take a pic for you to see what even 205/45/16 16x7 et 53 is so close the the swing arm in the rear !
evolutionmovement wrote:Yeah, if anything, you'll need to keep some sticky rubber on it to prevent it from locking up too much. Oh, and to use all that power to move rather than make smoke. I don't think brake fade would be a problem with so little weight, either. It's amazing how good that looks. It looks like you're building up a car that's only a few years old. I had two of the EA81s and I can say that even just 10 years took a real toll in corrosion, so I don't know how that looks so good. If you plan on driving it in the winter, I recommend undercoating the hell out of everything underneath.
i hope im not shredding the tires that much lets hope the awd of subaru helps out with that and the dccd set up i have.
it does look like a newer car with all these upgrades its still got nice lines !... no winter for this car at all its only coming out to race or a fun drive around in the summer. i been oil spraying everything as i go, might be adding allot of weight but i dont want it to rust at all.
FundamentalyConfused wrote:He's up in Canada evolution. They don't use salt on the roads up there. No rust belt like we have in the states.
i dont think you know how much salt ontario uses its gross !!! cars up here get destroyed little over one winter !! they are insane on the east... i hear in the west canada they use dirt !
brando wrote:Awesome..... Truly Awesome.
thanks man !
well rear is all done suspension knuckles and rims tires
and my amazing light weight battery came in and its in my winter beater to keep it warm for when the Leone is done
my old school momo hub found in germany !!!
flowmaster hush muffler !! only thing that can fit on this little car !
this is what my tip will look like after i weld it all up. but with a foot of pipe in the middle of the two.
my pipe 3' 304 polished
Looking good!
I'd recommend running the tip out the inlet of the muffler.
It would be so much more sleeper without the 'turbo' stickers, but they look so good.
I think the Turbo stickers are great! Old school and the truth hiding in plain site. Most people would think it was the just the stock 115 HP unit. It's like a wolf dressed like a sheep dressed like a wolf. Or maybe it's a sheep from that awesome horror movie, Black Sheep or it's a wolf . . . with a laser gun . . . in a . . . forget it, I don't know what it's like, but it's great.
NICO
Post by NICO »
beatersubi wrote:Looking good!
the muffler i think only works the right way.... i cant take the turbo stickers off its the factory ones, but it would make it more sleeper but im sure once they hear it it wont be to sleeper lol
evolutionmovement wrote:I think the Turbo stickers are great! Old school and the truth hiding in plain site. Most people would think it was the just the stock 115 HP unit. It's like a wolf dressed like a sheep dressed like a wolf. Or maybe it's a sheep from that awesome horror movie, Black Sheep or it's a wolf . . . with a laser gun . . . in a . . . forget it, I don't know what it's like, but it's great.
LOL ..... ya stickers will stay on for sure. out side only rims and brakes will give it away and the mad rumble it will give off. also it will be very very low. i can tell all ready with the 16inch on in the rear its got no gap and it sits perfect inside with no rub at all.
support for the front lip, oem subaru
put them on
Franz crazy at work on my wiring, this is only half the paper work on my stuff.
and the pin porn for the wiring he is doing for my hole car !
r180 read for service !
Pin porn! I love it :lol:
Is he using mil spec connectors?
NICO
Post by NICO »
Legacy777 wrote:Pin porn! I love it :lol:
lol ya.. i think its some aviation stuff. but its mil painted. i cant wait to get it all he has my vipec 88 all wires my id1000 injectors the factory service books oem of my year model and i forget what else lol.
Cool!
NICO
Post by NICO »
Legacy777 wrote:Cool!
:D
my brand new Bosch 044, these fittings are from the UK for the ford cosworth ! who would have guessed the Leone had the same set up !!
my hsd front camber plates came in ! thank you JRP for letting me do what i had to do to get my suspension all sorted out !!.
the front is a bit to low, which will come up after corner balance and aliment get worked out. i wouldnt want the honda crowd thinking i want to race lol.
