RckyMtnLegacy's 93 Turbo...On the Road Finally!
RckyMtnLegacy
Re: RckyMtnLegacy's 93 Turbo 'SadPanda' Rebuild Done, She ru
Post by RckyMtnLegacy »
Its a very long dp but if i plumbed it back farther and maybe made it 2.75 or 2.5 out would that help?
1990 2.2l Legacy--RIP
Keeping the Legacy's Legacy
Official Subaru Ambassador
RckyMtnLegacy
I do love her on the road though.
RckyMtnLegacy
Questions posted in Engine threads. Any help would rock
Did you get your questions in the engine forum answered?
I'm just now getting through the build journal threads.
RckyMtnLegacy
Yes I did! Thank you all. Oil in intake and on the firewall and smoke on start-up were all caused by too much oil. I did an oil change and measured out exactly how much oil I need and problem went away.
RckyMtnLegacy
Just got my JEGS U-Bend 3 inch pipes and 2 four foot SS 3 inch pipes and flanges for my custom exhaust.
Added a Nardi steering wheel with NRG 3.0 Quick disconnect and short hub.
turbo970
Post by turbo970 »
where did ya get the crank pulley
RckyMtnLegacy
Importimageracing.com my buddy runs it. Will beat any price
turbo970
Post by turbo970 »
i need a new one for my 92 if thats cheaper than a stock one i'll order one
RckyMtnLegacy
Lighter and looks better.
turbo970
Post by turbo970 »
well a one from orielly's is like 180 how much is this one
RckyMtnLegacy
120 max
turbo970
Post by turbo970 »
i'll try and order one when my subie goes to the shop
RckyMtnLegacy
turbo970
Post by turbo970 »
and that will work on my 92
RckyMtnLegacy
Worked on my 93
turbo970
Post by turbo970 »
sweet
RckyMtnLegacy
It has been a while so I figured I would show whats new:
Stock exhaust had to go
Ordered 3" SS pipe straight and U-Bend
Cutting and welding and more cutting
We set up the exhaust but the flanges and gaskets were missing so we left it open down-pipe for a while
http://youtu.be/Kmffx7ImRXY
RckyMtnLegacy
Finally tonight we finished off the welds and hangers
I miss the open DP but no rattles and now my girl can ride with me and not hate it the whole time. Hope to get a new exhaust video up too.
RckyMtnLegacy
Re: RckyMtnLegacy's 93 Turbo 'SadPanda' New 3" Exhaust!
SO.........I can hear a slight knock starting and its not making me very happy.
RckyMtnLegacy
Re: RckyMtnLegacy's 93 Turbo 'SadPanda' Knock Knock
^^^^^...and the knock has now shut the car down. Last night it died and when I started it back up I could hear the rod real bad. So now it is time to tear it apart, again. Anyone know someone that has a crank in case I need one?
Post by SILINC3R »
Well, that sucks hope it goes smoothly
You probably already know this, but the crank is the same between the non-turbo & turbo engines.
RckyMtnLegacy
And I did not know this thank you!
RckyMtnLegacy
Ok so the fun has now begun...
I split the block and as I was doing so found a few issues to address as I put it back together. (Remember this has been taken apart and put back together in DEC 2011)
1) Oil is caked all over the the bottom hose on my turbo that goes into the block.
2) Minor oil in the intake
3) Hard splitting harnesses to the sensors on the crossover
4) Spark plugs are a light grayish white color
5) Oil pressure sensor (New in DEC11) had oil all over it
6) Spray of oil on the hood above the belts
7) A/C support was loose and could move about a 1/4 inch front to back. And tore up two bolts.
8) Lightweight crank pulley is tweeked and the back looks like it is toast
9) Key on the crank is also tweeked
