TD04 swap fuel management question
alexandermf
Post by alexandermf »
sorry if its been covered but most of the td04 info i see are ppl asking about the 90* elbow and mounting questions.
im about to swap a td04 in my 93ss which already has a tmic. my question is, do i need a fuel management/tuning program to help with proper afr's or am i good to go to just slap it in. i purchased a turboxs mbc and a boost/vaccuum gauge to go along with the install. im not trying to turn the boost up and run like a raped ape, my vf11 is leaking/smoking and figured the td04 would be a small but decent upgrade
alexandermf
Re: TD04 swap fuel management question
one buddy said im good to go and another said he would recommend a psi fuel pressure regulator with gauge
Your ecu will be sufficient to handle the TD04. Since fuel cut is right around 14psi, so long as you have a healthy engine, you should be fine running it right below cut, since the TD04 is only a little bit bigger turbo.
Edit: WTDash pointed out that on a stock ej22t ecu, fuel cut actually occurs at or around 13psi.
James614
Post by James614 »
You'll definitely be fine. Fuel cut saves your bacon within a safe limit on the TD04. The RRFPR is really only needed when using a bigger turbo or an FCD to run past 14psi.
alexandermf
Thanks for all the help and input!
Sent from my PC36100 using Tapatalk 2
wtdash
Post by wtdash »
Just a heads up (and no offense to Mike) but Fuel Cut is @ 13 psi, per the Legacy Turbo FAQ. I point it out so you don't set your MBC @ 13 and wonder why every 3 seconds it cuts boost. Set it to 12 and you'll be good to go, depending on your elevation in CO.
Oh, and since you read all those posts about the 90 elbow and TD04 you're prepared, correct? :)
GL,
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
wtdash wrote:Just a heads up (and no offense to Mike) but Fuel Cut is @ 13 psi, per the Legacy Turbo FAQ. I point it out so you don't set your MBC @ 13 and wonder why every 3 seconds it cuts boost. Set it to 12 and you'll be good to go, depending on your elevation in CO.
GL,
TD
Oh whoops! I guess I'm thinking about my own ej20g 3C ecu. Good catch Todd!
alexandermf
Thnx for the fuel cut info and yes I'm ready to cut that 90 to fit nice and snug!
Sent from your bathroom closet
