EJ20G "RobTune" Info
dafrompa
Re: EJ20G "RobTune" Info
Post by dafrompa »
do u have to run an ej20 ecu and can you run a ej20 ecu on a N/A car? or can a ej22 ecu be tune?
The magazine is sweet.
logan9691
Post by logan9691 »
Any updates Rob?
VF43 custom FMIC APEXI intake Invidia 3" TBE JDM Ver. 4 RA STi trans (4.44) SPT short shifter rear LSD WRX rear axels coilover suspension JDM 4-pot front brakes drilled slotted rottors Greddy EBC tuned 20G ECU sti 550cc injectors Jecs MAF walbro 255
sqc151
Post by sqc151 »
robs got some super fast shipping. went from washington to jersey from thurs to monday. A++ in my book.
now i just gotta install it and have fun.
thanks Rob for everything.
monkeyposeur
Post by monkeyposeur »
I was given a non running 93 Touring Wagon for free. :-D It is missing a few of the air intake parts, but no big deal. My plan is to remove the longblock, harness, crossmembers, down pipe, brakes, etc., and swap it all into my second gen 95 BK. I'll take a year or so to build the motor and get all my ducks in a row.
Rob, would you want the SS ecu as a partial trade towards one of your 20G ecus, or am I better off finding a 20G on my own? I definitely want one of your ecus for my 22T swap into the second gen.
93 SS - SOLD
03 WRX 22T/205 20GXT 350 whp
06 OBXT
95 BK - Sold to my neighbor.
rob
Post by rob »
monkeyposeur wrote: Rob, would you want the SS ecu as a partial trade towards one of your 20G ecus, or am I better off finding a 20G on my own? I definitely want one of your ecus for my 22T swap into the second gen.
Thanks for the offer, but I don't have a need for the SS ECU. If you can find an ECU on your own, then that would be best. Otherwise depending on when you are ready I might have a spare to sell.
-Rob
logan9691
Post by logan9691 »
Rob, have you worked on anything new?
BoostedSubie
Post by BoostedSubie »
I'm picking up an ej20h tt this weekend, i'm wondering h ow your tune would work for it due yo the twin turbo motors having higher compression? It would be converted to single turbo of course.
93 Black Legacy SS
93 Legacy
97 Green Outback
97 Red Legacy GT
99 Black Legacy GT wagon
rob
Post by rob »
logan9691 wrote:Rob, have you worked on anything new?
Mostly just barely keeping up with current demand. Otherwise a little more work on the Z32 vaporware tune. Also started looking into EJ20K chipping.
BoostedSubie wrote:I'm picking up an ej20h tt this weekend, i'm wondering h ow your tune would work for it due yo the twin turbo motors having higher compression? It would be converted to single turbo of course.
Boy, that's a tough one to guess. If it's the 9.0:1 version, then probably a non-starter. There was also an 8.5:1 version. After that, I really don't know how the ecu pinout differs. Which MAF does it run? Couldn't you just buy a normal motor? :D
BoostedSubie
Well, I.m getting a super good deal on it or else I wouldn't even bother. I didn't pay attention to what maf it had but I do have a pic of the ecu, i'll look for it. Either way, the wiring will be for an EJ22t so I can repin it to work for the EJ20g. Its just the highe compression that I was worried about so i'll figure out what it is.
93 Black Legacy SS
93 Legacy
97 Green Outback
97 Red Legacy GT
Lego22T
Post by Lego22T »
I have a V5 G ECU headed my way and I'm excited to get it "RobTuned"!!! Nice thing is I have all the parts chillin' in my basement/workshop that I could run either tune option (including a full 20G top end). The 16g turbo needs rebuilt before I'd feel safe installing it on the car though.
So is it a common agreement that the higher tune (STi injectors) requires changing over to a FMIC or would a better quality TMIC do just as good of job? I have the 06/07 WRX on the car now with the TD04. I plan on a Hot Coat on the turbo along with a Perrin turbo blanket and wrapping the U/P & D/P to deminish heat soak. My main reason for asking is I'm trying to keep the car as close to stock looking on the outside as possible and a FMIC grabs a lot of visual interest from people.
'92 Legacy Sport - Daily Driver & SCCA AutoX (Class: SM)
"When in doubt, flat out!" Colin McRae 1968-2007
wtdash
Post by wtdash »
No...Rob Tune doesn't require a FMIC....
With the Rob Tune you'll be slightly above STi power levels (~275hp/torque @ the wheels w/the tuned ECU - 16G and 550's) - and the STi does fine w/the TMIC.
More important than the TMIC vs. FMIC, IMHO, is routing the air to/thru the TMIC.
I had the same setup (16G, 550s, '06/07 TMIC, Rob Tune) and suffered from heat soak during the summer, so I'd recommend looking for ways to get a good seal between the hood scoop and TMIC, a splitter/diffuser ...and a bigger scoop (Yeah, kinda ruins the stock look), which is a challenge unless you're good w/body work. Also, the turbo blanket and heat shield are good ideas.
Another option is Meth injection (but ask Rob 1st!!) or add an STi IC sprayer setup, to keep it in 'sleeper' mode.
GL,
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Lego22T
Post by Lego22T »
I've been working on a mold for creating a replica Liberty RS hood scoop. This will at least look like it belongs on the car but be taller to grab more air.
As for the intercooler, I've been more of a TMIC fan due to the drastic intake track length vs FMIC. So I guess I'll look into picking up an STi or aftermarket TMIC to upgrade from my 06/07 WRX.
wtdash
Post by wtdash »
^STi TMIC won't fit. The Legacy doesn't have as much space/depth(?) between the firewall and throttle body as WRX/STi. "Measure twice, cut once". :-)
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
James614
Post by James614 »
Insert shameless plug for AWICs here. Seriously though, stock look, stock scoop function if you keep the chimney, TMIC air path with FMIC dissipation location, only downsides are cost/weight and legwork for sourcing the extra parts (mine was around $350 total). It can un-heatsoak itself with the car stationary if you have a good heat exchanger. They're freaking awesome.
wtdash
Post by wtdash »
^+1 for AWIC....
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
oldscoobyturbo
Post by oldscoobyturbo »
+2 AWIC
a little biased here but it does work awesome
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
sqc151
Post by sqc151 »
+3 awic.
im selling a complete set up now.
will bolt to any factory turbo (usdm or jdm) except the vf11.
logan9691
Post by logan9691 »
any updates Rob?
LookAsubie
Post by LookAsubie »
So I'm having troubles here. Got everything in and the car won't start.. I don't know what the problem is, but it's not getting spark for some reason. It sits there and cranks but will not start, I can smell that it is greeting fuel. Double and triple checked the wires from the converter into the ecu, they seem good.. Checked the cel code and it is 45, which is the pressure sensor right? Could that cause it not to start? Did I do something wrong? Anyone else have this problem?
1992 legacy SS 5mt, Winestone Metallic.
LookAsubie
Someone help me out?
wtdash
Post by wtdash »
LookAsubie wrote:Someone help me out?
45 is the either MAP/pressure sensor or pressure exchange solenoid.
1. How did you wire in MAP sensor? The correct way is to remove pin 5 on B48 and join it with pin 21 on B48 @ the ECU connector.
2. How did you actually connect everything? Solder, crimp connectors, etc??
3. How did you wire in the converter? Verify each step from Rob's post HERE (half-way down).
Pic:
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
ScottyS
Post by ScottyS »
I emailed Rob probably 3 weeks ago stating that I'm ready to purchase his whole kit, but have heard nothing back yet.
1991 SS build thread: http://bbs.legacycentral.org/viewtopic.php?t=40430
Dominator
Post by Dominator »
^^ I haven't heard from him either. It'll be a month tomorrow since I sent him money.
wtdash
Post by wtdash »
That's a little long...even for Rob. I checked out his activity on NASIOC and hasn't been there in a month either.
Must be on vacation??
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Oh wow. Weird. I haven't seen him on in quite a while and I haven't heard an update on the EJ22T ECU in ages. I think he just lives a busy life and has higher priorities. But that's no excuse if you've accepted money from someone. Does he know you sent him the money?
