STi parts were all bought for an earlier project. Project was cancelled so most aftermarket bushings were never on the car, just pressed in. Mileage is unknown, unless otherwise noted.
2004 STi rear subframe $60
2004 STi Rear Diff carrier with Brand New Whiteline outrigger bushings already pressed in $60
2004 STi C.Diff/mirror adjust $20
2004 STi Bosal Twin Tip exhaust $250
2004 STi OEM Fuel Rails $15
2004 STi Rear Brembo bracket thingies $20
2004 STi e-brake handle $30
2004 STi frame cross member brace $25
2004 STi Trans cross member w/ brand new Whiteline Front Gearbox Positive Shift Kit (part#: W0584) installed $60
2004 STi ABS Sensors $50
2004 STi Directions Sensor $50
2004 STi Shift Knob (looks like a pro drive replica, but not sure if it is actually prodrive) $10
2004 STi Front Rotors $40
2004 STi Rear Rotors $40
MISC. Parts:
Gasket OEM (Idle Air Control) 22659AA060 $3
Gasket OEM (throttle chamber) 16175AA201 $2
JDM Control Arms with Brand new Whiteline LCA bushings already pressed in $200
Whiteline Anti-Lift Kit: KCA319A BRAND NEW $180
Whiteline Steering Rack Mounts: KSR202 Brand New $25
Whiteline Sway bar link kit-h/duty adj steel ball KLC139 BRAND NEW $100
Legacy Specific Whiteline Adjustable 22mm Front Sway Bar (BSF18X) BRAND NEW: $160
