lowering springs for wagons
turbo970
Post by turbo970 »
so are some of the lowering springs they show online so far all say for sedans. will they still work on the wagons? i want to do a mild drop next spring
Thesubielover
Re: lowering springs for wagons
Post by Thesubielover »
I havent seen any online for the wagons. Did some research and called h&r. Call there customer service number and ask for ryan. See what he says. I have a sedan, you may need to go with wrx components.
turbo970
Post by turbo970 »
hope they have something that works. or i could bite the bullet and get coil overs
turbo970
Post by turbo970 »
i found these but not sure if my ride has the right code that they show
http://www.yourhotcar.com/prod/Intrax/S ... 06/557904/
Thesubielover
seem like these could fit. i think you should call this website, or maybe both just to verify. it will save you the hassle.
turbo970
Post by turbo970 »
true true
The springs for the sedan should physically fit as long as they're for the correct application. Since the wagon is a little heavier in the rear, you might get a saggy rear end with sedan springs, but more than likely, they'll be fine.
turbo970
Post by turbo970 »
what does the j6 code mean?
topsecret888
Post by topsecret888 »
turbo970 wrote:what does the j6 code mean?
Those springs u looked at should fit fine. I believe J code meant that it's the BJ code that's for the first gen legacy wagons. Besides, those intrax springs also specifically made for 91 and up legacy wagons, so u should be good to go.
WagonMafia
Post by WagonMafia »
Tein S Techs on s/r kyb gr2s 02-04 wrx wagon springs, 2" drop all around, on 17s looks nice, rides great.
WagonMafia
-Pure White 93 L Wagon converted to Turbo Wagon (almost complete)
-Pure White 92 SS parts car (doner) donated to friend
-91 Mazda miata drifto DD
http://photobucket.com/wagonmafia
Thesubielover
Nice input, I was thinking 16's with a 2in drop, but 17's clear and do you have wheel spacers?
Someperson
Post by Someperson »
I'm looking for about a1" drop on 16s and AGXs, any ideas?
93 Winestone TW project
WagonMafia
No spacers, I'm not pos of the offset on the wheels, but they're 17x7 with a 205/50-17
WagonMafia
robertpaige
Post by robertpaige »
Just grab some GC Raceland coilovers. They ride great and look awesome.
turbo970
Post by turbo970 »
when i get my subie back i may try those raceland coil overs. my folks talked to the trans mech. and he said he should be done in a week or 2
WagonMafia
I have a customer with the racelands on his o/b limited, looks tiiiiight.
WagonMafia
turbo970
Post by turbo970 »
i wont get a harsh ride with those will i?
WagonMafia
Never had coilovers on any of my rides before, I couldnt tell you. I can imagine it won't be as plush as stock, but that's to be expected.
WagonMafia
turbo970
Post by turbo970 »
well i'm hopen to get the car back in a couple weeks
Rubasu
Post by Rubasu »
i run Racelands and actually like them over the cusco coils i had. Race lands are cheep but thes have a good spring rates and are comfy in my wagon.
90 legacy Wagon LS Special, JDM closed deck 20g, custom 25d heads f/ metic motors, APS GC FMIC, 740cc, VF34, 4.11 F/D, Turboxs RFL blow off valve, now with piggyback.
94 Legacy SS R.I.P (parts car now for 90)
97 Legacy Outback (sold)
WagonMafia
How cheap?
WagonMafia
Rubasu
Post by Rubasu »
less then 500 new cheap. i really do like them and they can last you a while if you take care of them.
Rubasu
Post by Rubasu »
Yes i know my headlight and hood is messed up. got in a fender bender not to long before i took this pic. but this is how low i have my race lands and dont rub. fenders rolled not pulled though. and i have cusco camber plates front and rear. race land does offer camber plates as well.
turbo970
Post by turbo970 »
do the gc's bolt right on with out any mods?
Rubasu
Post by Rubasu »
yep. fit right in to our cars
