Below is a quick history of the car and the current modification list. I still plan to provide more details about the mods, but that will come at a later time when I can get that all typed up. Thanks to Michael (DerFahrer) for the proof reading and feedback on the write-up.
A 1990 Legacy’s Journey from
this…
to…
History
This Legacy started life as a naturally-aspirated, front-wheel-drive, automatic 1990 Legacy L. It originally belonged to my grandfather, and I inherited it in 1995 when he passed away. It had 80,000 miles on it then and has taken me through high school, college, nine cross-country trips, and a transformation from something ordinary to what you see here today.
At currently over 196,000 miles on the chassis, this Legacy has seen its share of miles, modifications, and adventures. Almost every component other than the main chassis has been modified, replaced, or upgraded. It has undergone two major conversions/swaps in its lifetime, including a swap to all-wheel-drive and a manual transmission in 2004 and a swap to a rebuilt EJ22T engine from a Legacy Turbo in 2005. The engine has been rebuilt a second time with forged internals to compliment the larger turbocharger, custom air-to-water intercooler setup, and fully programmable standalone engine management system. Current horsepower and torque levels are approximately equivalent to a stock STi. In 2013 I completd an STi 6spd transmission swap to replace the Turbo Legacy 5spd I previously swapped in.
This car's transformation has been an amazing journey, and I hope you enjoy seeing it as much as I've enjoyed building it.
I recently had the engine tuned and it made 255 hp & 306 ft-lbs at the wheels. Dyno comparisons & plots can be found here in my build thread.
Modifications
Engine
- • Ej22t engine swap
• Late model Subaru 45 deg. intake box
• Custom intake piping with fender snorkel removed
• Deadbolt ported & polished and ceramic coated TD05-16G turbo
• Samco turbo-intercooler silicone hose
• Overseas Subaru AWIC core w/ aftermarket upgraded pump & custom front mount heat exchanger
• Throttle body coolant bypass modification
• Walbro 255 lph fuel pump
• STi yellow top 550 cc/min injectors
• Calico coated ACL race crank & rod bearings
• Eagle Racing forged rods
• Wiseco forged pistons (8.5:1 compression ratio)
• ARP head studs
• Delta Cams 220 “torque” reground cams
• Crawford performance adjustable timing belt idler pulleys
• STi oil cooler
• MSD DIS-2 ignition
• Diamond coil pack
• NGK 8mm performance wires
• High output (140 amp) WRX alternator
• LinkPlus G3 ECU running G4 Xtreme firmware
• Link DisplayLink
• AEM 100 psig fuel & oil pressure sensors
• Delphi oil temp sensor
• Delphi intake air temp sensor
• GM 3 bar MAP sensor
• GM boost control solenoid
• WRX knock sensor
• Exhaust Gas Technologies EGT sensor & 5v amplifier
• Swaintech “White Lightning” ceramic coated turbo up-pipe
• Overseas Subaru equal-length exhaust manifold with Swaintech “White Lightning” ceramic coating
• Custom Exhaust Systems 3” stainless steel turbo back exhaust
• Zeitronix ZT-2 wide band O2 sensor
• STi hardened rubber motor mounts
• N1 lightweight aluminum power steering and alternator pulleys
• Greddy oil catch can with custom crankcase vent system
- • AWD & 6spd manual transmission swap
• 2004 STi 6spd transmission w/ Surtrac LSD
• DCCD Pro DCCD Controller
• Subaru STi flywheel
• Subaru STi clutch & pressure plate
• STi hardened rubber transmission mount
• VLSD rear differential
• Larger diameter (FWD) front CV axles
• Custom stainless steel braided clutch hose
• Offset clutch master cylinder reservoir
• STi shifter and linkage
• Custom shifter joint bushings
• Kartboy front and rear shifter stay bushings
• TiC shifter lever bushings
• Subaru Xtra-S transmission fluid
- • SPT front strut tower brace
• GC Impreza rear strut tower brace
• STi hardened rubber strut top mounts
• Whiteline Control lowering springs
• Whiteline coil quieters
• KYB AGX adjustable struts
• KYB bump stops & boots
• Whiteline polyurethane steering rack bushings
• Whiteline 22 mm front anti-sway bar
• Whiteline front anti-sway bar end links
• STi hardened rubber A-arm bushings
• STi hardened rubber transverse (rear A-arm) bushings
• Whiteline rear sub-frame lock bolts
• Whiteline polyurethane rear sub-frame (outrigger) bushings
• STi hardened rubber rear trailing link bushings
• Whiteline adjustable rear lateral links
• Whiteline HD rear anti-sway bar mount
• Whiteline 20-24 mm adjustable rear anti-sway bar
• Whiteline rear anti-sway bar end links
• Performance alignment
• TiC fender braces
• Racing Gear Type M7 wheels
• Goodyear Eagle F1 GS-D3 tires
- • Impreza single diaphragm brake booster
• 1-1/16” bore SVX 4-port non-abs brake master cylinder
• MRT brake master cylinder brace
• First gen. Legacy wagon brake proportioning valve
• Goodridge stainless steel braided brake hoses
• WRX front brakes (11.57” vented rotors)
• Legacy GT rear brakes (11.42” vented rotors)
• Slotted and cryo-treated Subaru rotors
• Mintex 1155 brake pads
• Valvoline Synpower brake fluid
• Painted brake calipers (pin striped matched)
- • EDM glass headlights with electronic levelers and city lights
• Upgraded headlight wiring with relays
• Osram H4 headlight bulbs
• Optima Yellow Top deep cycle battery
• Upgraded ground and power wiring
• Tsunami TSBT-PN battery distribution terminals
- • Custom manual seatbelt conversion
• 2002 WRX seats
• Autometer Z-Series vacuum/boost gauge
• Custom leather shift boot & WRX shift knob
- • Turbo Legacy hood w/ scoop
• Turbo Legacy rear trunk spoiler
• Custom painted front grill
• STi B4 Legacy Rabbit emblem
• Hella Supertone horns
• Passport 8400 radar detector
• 20% window tint
- • Rockford Fosgate power & ground wire
• Rockford Fosgate RP7400 1 farad capacitor
• Monster Cable RCA’s
• Rockford Fosgate upgraded speaker wire
• Alpine CDA-7940 CD receiver
• Phoenix Gold PLD1 line driver
• Phoenix Gold EQ215x equalizer w/ remote subwoofer gain control
• Alpine MRV-F401 amplifier
• Infinity Kappa 63.1i & 62i speakers
• Custom front speaker spacers
• Rockford Fosgate Punch 200x2
• JL Audio 12W-D4 subwoofer
• Custom subwoofer enclosure
• Custom amplifier mount rack
• Ported trunk/deck lid
• Dynamat Extreme sound deadening
• Clifford Intelliguard 800 IQ alarm w/ dual-zone proximity sensor
