So I bought the interface off the ECUTuner website first and the the USB plug.
Then I took them out of their packing and plugged them together like so.
I went to the ECUTuner website and downloaded the ECUTuner apllication and the definition files for my 90-91 N/A.
Then I took my laptop, the harness and went to my car. From there I found the yellow plug that you will plug the white plug into. There is only one way to plug it in. I did this with the car off.
Once you have it plugged in, plug the USB into your computer and the driver will start loading on its own.
Now you should be good to go and use the ECUTuner application to view different things. Unfortunately the ECUTuner application isn't working properly on my computer so I'll have to talk with Michael to try and solve this. A little hick-up but so far is pretty straight forward. I will be trying to update as much as I can when I can. Michael spent a good deal of time developing this for us and it never took off so I am happy to try this out and see what happens.
Parts and prices:
90-91 N/A ?
ECUtune OBD1 select monitor interface cable- 87.50 shipped ECUtune
FTDI TTL-232R-5V USB Cable- 39.09 shipped fdtichip
computer ?
